Zoom only partially works when recording
600 10 2023-7-23
Jo060
Flight distance : 2513104 ft
I purchased OM SE yesterday.
I noticed when I'm recording video, I can only zoom from 0 to .9x, it won't go past that. If I turn off recording it will go to max zoom without issue. If I start the zoom past .9x and start recording it does the full zoom no problem.
Is this normal?
2023-7-23
Jo060
I'm using Galaxy S21 ultra and developer options are off.
2023-7-23
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please provide us a short video or screen recording showing the issue so we can check it further? Please keep us posted. Thank you.
2023-7-23
Jo060
DJI Paladin Posted at 7-23 05:35
https://photos.app.goo.gl/bjXe23RHBXCNUbuJ8
As you can see in the video. Once the app hits .9 it stops. I try to force the zoom with the button but it won't budge. Oddly enough, when I was using it earlier, the zoom worked fine but now it doesn't.
2023-7-23
Jo060
I have reinstalled the app again and that seemed to have fixed the problem for now.
I've noticed when zooming, the image becomes grainy fairly quickly despite not being much over 1x zoom. When I use my native camera app, the image is crystal clear even on a stronger zoom.
Is there a way to improve the zoom quality or is that an app issue?
2023-7-23
Jo060
Hi
I'm having the same issue again. Any ideas?
2023-7-26
DJI Paladin
Jo060 Posted at 7-26 17:51
Hi
Hello there. Sorry for the late response. We appreciate you for sharing the details of your test with the unit. Please confirm if the issue only appears when using the DJI Mimo app and not the original camera app, correct? In addition, the link that you provided is no longer working it says "Album is empty". Please keep us posted. Thank you.
2023-7-27
Jo060
DJI Paladin Posted at 7-27 05:50
After doing research, this is a known issue. Samsung and the Mimo app are not fully compatible.
I'll try a different option.
2023-7-28
DJI Paladin
Jo060 Posted at 7-28 14:27
Please keep us posted after you perform some tests. Thank you for your continued support.
2023-7-30
Jo060
DJI Paladin Posted at 7-30 02:21
I've returned the item. It's a known issue... Tests won't correct the issue.
2023-7-30
DJI Paladin
Jo060 Posted at 7-30 02:56
Thank you for your response, Jo060. We're sorry to know that you came up with a decision to return the unit. Should you have other inquiries or concerns, feel free to contact us. Thank you.
2023-7-31
