Depp
Flight distance : 1868796 ft
chrisnorway Posted at 8-5 13:46
Thanks! Trying to fly as smooth as I can. I think the quality is ok, but GoPro definitily is a bit better. just got myself a gopro + mount so looking forward to trying that out. Mostly for the stabilization, which is lacking in the DJI camera, really annoying because if you make one small mistake it messes up the flow, so you have to fly perfectly smooth the entire time.
Well if you're good enough at the sticks (I'm not - once in Madeira my GoPro failed and I had to use the DJI footage - had to slow it down to 50% to make it close to smooth) then maybe that's the best solution.
I switched to a GoPro 10 mounted on top plus Reelsteady and never looked back. |
