DJI Paladin
Hi there. Thank you for reaching out. Press the C1 button on the remote controller to create a waypoint, and press the C2 button on the remote controller to delete the current waypoint. In addition, DJI Inspire 3 does not support deleting the entire flight route on the camera view. It currently does not support tapping and holding the route and sliding to delete it.
To delete the entire flight route when using the DJI Inspire 3, follow the steps below:
1) Enter the homepage of the DJI Pilot 2 app and tap “Flight Route”.
2) After that, tap “Select” in the top-right corner, check the flight route to be deleted, and tap the “Trash Can” icon in the lower part on the Flight Route Library panel. Then, the app will prompt “Are you sure you want to delete the route from the library?”, and tap “Delete”. |
