Combat Command
Thanks, for the quick post.
I agree that it is supposed to wiggle. But this condition the white rubber pieced had room to move vertically up an down. Its strange because I took pictures prior to dissassembly and the two corners that had the plastic attachments did not have the ring above and below the structural frame holes, they were actually in between the top and bottom, the corners without the plastic pieces had the upper and lower ring through the holes on the brackets.
So after I posted I put all four corners together the same way and installed the plastic pieces...everything is like new now, problem solved. Very strange. If you happen to look at yours...are those rings throughout the mounting holes? Or are they in between? |
