HDMI out from DJI RC?
15606 18 2023-8-20
sivaci2754
India
This may be a question asked frequently, but from what I have seen from web searches, there was no definitive answers to this question, and the specifications from the DJI website did not help. I want to purchase a drone, preferably Air 3 or a Mavic 3 classic. They come with DJI RC / RC 2 and N1. Is there any way to get HDMI out from these RCs? Dont have any friends who owns these drones. Thanks
2023-8-20
Flormo2002
Flight distance : 12425794 ft
Dirty Bird Posted at 8-21 04:03
None of the controllers you list support HDMI out.  You would need to purchase the RC Pro if you require HDMI out.
However, if you decide to purchase the Air 3 instead of the Mavic 3 Classic, the RC Pro is not compatible with the Air 3
2023-8-21
DIY_Quad
Yup, no easy way to get HDMI out from DJI controllers that I had to do this;
https://forum.dji.com/forum.php?mod=viewthread&tid=233756
2023-8-22
DJI Gamora
Hi, sivaci2754. Thank you for reaching out. RC-N1, DJI RC, and RC-N2 do not support HDMI output. DJI RC 2 does support HDMI output. However, the output function has not been compatibility tested, so there may be issues like unstable transmission or lag during use. It is recommended to test it before live streaming to ensure stable transmission before using this feature. Thank you for your understanding.
2023-8-30
fans9a3ea4a9
Flight distance : 116827 ft
DJI Gamora Posted at 8-30 07:41
I tested with 3 different types of USB-C to HDMI converters and it only worked with one. With this one the video quality was good, no too laggy, but when I disconnect the HDMI cable the RC-2 gets stuck and restarts, so the connection with the drone is gone. I'd say it's an issue with the driver in the RC-2.... But in any case, I think it's too risky to use it at the moment. I hope DJI fix it somehow, it's not good that an external device is able to restart the controller.
2023-10-16
Tuxtard
Flight distance : 9975610 ft
Serbia
You can connect DJI RC to HDMI with a special type of USB adapter, but it requires driver installation on the RC.
2023-10-29
Glass Man
I can confirm this works with the RC that came with my new DJI Air 3, it's the RC with the built-in screen.   I used my Apple USB-C to HDMI device that I usually use with my iPad to play iPad videos on my TV.  But instead, I plugged that Apple USB-C to HDMI adapter into the slot on the bottom of the DJI RC.   I plugged an HDMI cable into that Apple adapter, and connected the other end of the HDMI cable to a GUERMOK HD Audio/Video Capture device.  This capture device has a female HDMI socket on one side, and a USB-C plug on the other end.   I plugged that capture device into an iPad Pro.   On the iPad I installed a free app called Orion that is intended to make your iPad into a computer monitor. It worked great with minimal lag between the controller and the iPad.  The purpose of this setup was to allow a second person to monitor the video while I was flying the drone.
Don't be fooled by the apparent black color of the RC (in the picture in the next post). It's not the RC Pro - it's just the normal gray RC that comes with the Air 3, wrapped in a protective rubber sleeve, along with an attached cover/glare shield.
2023-11-14
Glass Man
2023-11-14
Helivideo
Flight distance : 11222717 ft
Serbia
Tuxtard Posted at 10-29 00:22
Thanks.
Can you give more details about this?
2023-11-21
Tuxtard
Serbia
Helivideo Posted at 11-21 15:01
Thanks.
Sure, I'll make a video to explain it better.
2023-11-22
aaWWaa
Anyone tried USB to USB portable monitor?
2023-11-26
djiuser_MeAXfUonseBk
India
send some detail about that
2023-12-13
Tuxtard
Serbia
Thanks.
I created a new topic with the explanation video.
https://forum.dji.com/forum.php?mod=viewthread&tid=303348
2023-12-14
Visualeyes
Is there any way to turn off the OSD on the HDMI output from RC2?
2023-12-19
DJI Tony
Visualeyes Posted at 12-19 15:57
Hi, Visualeyes, The DJI RC 2 does not support HDMI pure camera image output. However, we will forward your feedback as a suggestion to the related department. We appreciate your patience.
2023-12-19
mini3djirc
Flight distance : 3793 ft
how did you put in full screen that rc?
1-1 11:20
Dingaling
Flight distance : 15807 ft
Tuxtard Posted at 2023-10-29 00:22
Driver installation on the RC?  Did you find a driver and manage to install it?
1-6 09:28
Tuxtard
Serbia
Dingaling Posted at 1-6 09:28
Yes, more info here:
1-9 03:19
djiuser_bAzMsmqQioF0
Flight distance : 1895525 ft
Hi Friends,  This appears to be a viable solution for getting Clean video from the DJI RC-N1 or DJI RC-N2 controllers.   I've ordered one and will report back with details once I have tested it.
What is it?  Its a rasberry pi controller that takes the signal from your RC-N1 or RC-N2 via USB-C and outputs to HDMI.  CLEAN HDMI, without sound
Cosmostreamer.
Comes in two flavors:
- DIY, plans and a license to use it - $150
- Ready to use: $300
Features
For drones which are works with DJI Fly application
Only DJI RC-N1 or DJI RC-N2 controllers are supported! Not working with DJI RC, RC2 or DJI RC Pro.
Tested with drones: DJI Mini2, DJI Mini3, DJI Mini 3 Pro, DJI Mini 4 Pro, DJI Air, DJI Air 2, DJI Air 2S, DJI Air 3
Video receiving from DJI Fly drones (video only, no audio!) and output on HDMI
The demo videos are no very high in production quality, but I've seen enough to give it a try.
youtube -
Website: [url]https://cosmostreamer.com/products/djiflydrones/[/url]
1-24 16:53
