DJI Gamora
Hi, mpoczynek. Thank you for reaching out and we're sorry for the inconvenience. Regretfully, we don't send out backup units if your unit was sent for repair. You mentioned that the remote is not charging. So we assumed that it was not powering on anymore. If so, please try the steps below (feel free to skip the step/s if you have performed them). If not, please let us know.
1. Please check if you power it on correctly. The power-on method: Press the Power Button for one second, then again, hold it to power the remote controller on.
2. Please press the power button once to check if the battery level LEDs are light on. If not, please charge the remote controller, and then try it again. If the remote controller cannot be charged, please replace the charger if possible. If it still can not work, please send back the remote controller along with the crashed drone for proper diagnosis as well as the other issues you're encountering with the RC Pro.
3. If the battery level LEDs are light on, please try to connect the charger, then power on the remote controller to see if it is normal, if not, please send back the remote controller along with the crashed drone. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at (https://www.dji.com/support). Thank you for your understanding and support. |
