Terra reconstruction error with 1073741845
1256 4 2023-9-5
djiuser_KzZfjbGQO7RZ
Hi guys,
I am always getting the reconstruction error of 1073741845, when doing 2d modal reconstruction.
The log ends with the below lines. Full log file is here: https://file.io/v1PwGrCd1DWX
[SdkLog              ] [10:23:07.479] [I]map tiles generate finish
[SdkLog              ] [10:23:07.479] [I]post process start
[2023.09.06 10:23:07.480] [SdkLog              ] [10:23:07.480] <TerraLog>pmw2FIMTGN6tGvAnN8XHxZoRGy7qrGLi_ObLzSWjghAtNL7fIBSUPZ_YuHyx49eL<endl>
[2023.09.06 10:23:07.481] [SdkLog              ] [10:23:07.481] <TerraLog>oDnaMo990qfW3QfA0zxK0DOvjcZsQGe5nT3c1u-am6nlkfJ2__ycVPzb3qtSa5Fi9_ud_X07MbXjXMiiQ-QHgg..<endl>
[2023.09.06 10:28:05.076] [SdkLog              ] [10:28:05.076] <TerraLog>1hzd9nBT7aWHD23N0EgP76s6BTkV5-CPzjbBnptFcQ49nv7c0Lw8AiQPhdrs9fbnrzL1OjdUaK_0eCIIWWp4wA..<endl>
[2023.09.06 10:28:05.076] [SdkLog              ] [10:28:05.076] <TerraLog>7ofuGRRRRYqkGujYmhTD71sliriPu_qNiE0DbX9RXxY.<endl>
[2023.09.06 10:28:05.077] [SdkLog              ] [10:28:05.077] <TerraLog>INJKQ7VkuMMaGFhSXsvdpFzN73nZnMQxKJ08mvmq8vs.<endl>
[2023.09.06 10:28:05.078] [SdkLog              ] [10:28:05.078] <TerraLog>c9IVpM-TV2MZ6v4rWBVElXjAx485AsAlwHVaOF8ZNXkyx1sABYw_38Wi6aKWJuo3<endl>
[2023.09.06 10:28:05.997] [ext_app             ] Normal [C:/Program Files (x86)/DJI Product/DJI Terra/Assistant/map_gen/DJIPicMapGen.exe] exit with 1073741845.
Any one can help? Is that related to antivirus or something else?
PC spec should be ok, with 4G gpu and 32G memory. Disk storage is fine.
[I]Device id: 0, name: NVIDIA GeForce RTX 3050 Laptop GPU, memory in GB: 3.999512
[I]Worker Master_LAPTOP-K5EO6M35_UGCF2T, usable memory 23.431187
Thanks!
2023-9-5
DJI Susan
Hi there, sorry for the issue, please allow us to confirm this with our engineers first, we will keep you updated.
2023-9-5
DJI Susan
Hi there, I am sorry for the waiting. Please check the following information:
1. Please check the cache directory space and reserve 5 times the size of the original data.
2. Please confirm the number of the pictures you imported. Thank you.
2023-9-9
djiuser_bsTrkDdZb1wr
Hello.  I am also having the same error.  I have 50GB worth of DJI L1 data; I have 773GB free on the drive where the cache is.
2023-10-5
djiuser_bsTrkDdZb1wr Posted at 10-5 22:44
The problem was fixed by removing "unrelated" photos from the folder. I have some other photos in the selected folder, and that was the cause of the error.
As soon as I separated those photos out… problem solved!
2023-10-8
