DJI Mic not working with Samsung S23 Ultra
1629 6 2023-9-7
JIlesMcCoy
Located in the USA. Samsuing S23 Ultra. The mic isnt recognized when plugged in to the phone. Works perfectly with iOS, bu t I need this S23 to work too.
Extensive searches have not turned up any working solution.
Thanks in advance for any help.
2023-9-7
DJI Wanda
Hello, there. Sorry for the inconvenience. Would you please perform the following troubleshooting steps?
1. Check whether the mobile phone adapter is mounted firmly:   Check whether the mobile phone adapter is mounted firmly in place and not loose.
* When connecting the DJI Mic receiver to the mobile phone, please apply force to the mobile phone adapter. If force is applied to the DJI Mic receiver, it can easily be detached from the mobile phone adapter.
2. Did you test it with another Andriod phone?
3. Try to use the other end of the mobile phone adapter to connect the mobile phone and test again.
2023-9-15
fans816a2d8f
India
DJI Wanda Posted at 9-15 05:38
Is there any country based restrictions for S23 ultra?
2023-12-4
DJI Wanda
fans816a2d8f Posted at 12-4 19:12
Hello, there. We are sorry for the inconvenience but we are unable to follow your questions. Could you please expand on your questions so that we can give you a correct answer?
2023-12-5
fans816a2d8f
India
DJI Wanda Posted at 12-5 03:42
Is there any restrictions to use DJI mic with S23 Ultra(which was bought in Australia) in any other countries like India. If not then the DJI mic is working fine with other samsung phones like S22 Ultra but not with the S23 Ultra. Is this a common issue?
2023-12-5
DJI Natalia
fans816a2d8f Posted at 12-5 19:42
Hey there, thank you so much for your reply, your issue is not affected by the district difference.
Please try the troubleshooting steps below:
2023-12-7
TexasStar15
DJI Natalia Posted at 2023-12-7 01:28
What do you mean by try to use the other end of the mobile phone adapter to connect the mobile phone?  I also can't get my DJI Mic and Galaxy S23 Ultra to work together.
1-6 11:00
