dji.blitzk
Flight distance : 1752986 ft
More options for C1/C2 in general.... This could be powerful but the options are very limited!
Specifically be able to manually set the camera tilt angle. Currently you can select 0/90. I often need the camera at 45degrees.
Option 1: be able to manually enter which 2 angles to have the camera set to. IE: 0/45. or 45/90. Maybe even 20/70 or something odd like that.
Option 2: Add 45 as a "third" option. IE: 0/45/90. (at each button press move 45 degrees).
Another option: use the rocker switch/gimbal tilt wheel to "snap" to a specific point. IE: If I "flick" the wheel up or down from 45degrees it will jump to 0 or 90. In use: if the camera is at 0, I flick down on the wheel and it snaps right to 45. I can then flick it up or down to go back to 0 or go down to 90. Once I'm at 90, one flick up will go to 45 and another flick up to 0....etc etc
Thoughts?
