Sean-bumble-bee
Flight distance : 15997 ft
Space Dream Posted at 9-30 23:36
Yes, so far I find this also the fastest method but I would like to have a USB connection M3P to Mac or PC without turning on the drone and thus without this memory card change to be able to transfer the data. I do not know if this is now possible with the new M4P ? Would find that in any case very good.
I have seen a post that made mention of a 'low power mode' in connection with one of the 'new' drones but I can't remember which drone it was. From memory the post showed it to be an option in one of the Fly App menus. If it was the mini 3 pro then it might be worth trying a download of imagery using the drone to read the card but I have no idea of the transfer rate.
However, I would ask, why would it be quicker than putting the card in a reader attached to the computer? They are presumably both USB connections.
If there is no 'low power mode' in the mini 3 pro then you would probably have to direct the draught from a fan over a powered up mini 3 pro that is 'reading' the card, otherwise it may overheat.
I also recollect seeing a video of the Mini 4 thing you mention and whilst it's a great idea I, personally, am wary of using a/the USB connection on the drone any more than is absolutely necessary but I have to admit that that is due to my considering the older style "micro USB" connections to be fragile, I do not know if the same worry is applicable to USB-C. |
