Does the Mini 2 and Mini 3 Use the Same Remote?
5306 11 2023-10-9
Sky Biscuit
Flight distance : 2899626 ft
Does anyone know if the Mini 2 remote is compatible with the Mini 3? I can't make out what model my remote is, and I can't seem to find a clear answer. Thanks!
2023-10-9
Sean-bumble-bee
Flight distance : 15997 ft
Physically I think both drones can use the RC-N1 controller which is also known as the RC231 controller BUT I think the controller uses differing firmwares with each drone model ...... because the communication protocols are different, see page 68 of the ver 1.6 Mini 3 Pro manual
"DJI RC-N1 Remote Controller
Transmission
Video Transmission System When used with different aircraft hardware configurations, the DJI
RC-N1 Remote Controller will automatically select the corresponding
firmware version for updating, and support the following transmission
technologies depending on the linked aircraft model:
a. DJI Mini 2/ DJI Mavic Air 2: O2
b. DJI Air 2S: O3
c. DJI Mavic 3: O3+
d. DJI Mini 3 Pro: O"
. THe Mini 2 uses the OcuSync 2.0 protocol whereas the mini 3 uses the OcuSync 3.
2023-10-9
DJI Diana
Flight distance : 2408 ft
Hello, there. Thank you for bringing this query with us. Please know that the DJI RC-N1 model can be used with the DJI Mini 2 and DJI Mini 3. When used with different aircraft hardware configurations, both remote controllers will automatically select the corresponding firmware version for updating and support the following transmission technologies enabled by the hardware performance of the linked aircraft models. I hope this information helps. Thank you for your support.
2023-10-9
Sky Biscuit
DJI Diana Posted at 10-9 14:37
Thank you for your help!
2023-10-10
Sky Biscuit
Sean-bumble-bee Posted at 10-9 13:30
Thank you! Sounds like it should work. Worst case I'll just have to buy a remote later, I guess.
2023-10-10
DJI Diana
Sky Biscuit Posted at 10-10 11:00
You're most welcome. Please feel free to reach us anytime! Cheers!
2023-10-10
Sky Biscuit
DJI Diana Posted at 10-10 13:52
Actually, I do have another question now, that I'm shocked I can't' find the answer to. Do you know if the Mini 3 and the Mini 3 Pro can use the same battery chargers?
2023-10-16
Sean-bumble-bee
Sky Biscuit Posted at 10-16 11:40
https://store.dji.com/uk/product ... ging-hub?vid=114201
2023-10-16
DJI Diana
Thank you for getting back to us. Yes, you may use the same charger for the DJI Mini 3 Pro and DJI Mini 3. Please see the available links below. I hope this information confirms your query. Should you have further concerns, kindly let us know.
https://store.dji.com/product/dji-30w-usb-c-charger
https://store.dji.com/product/dji-mini-3-pro-two-way-charging-hub
2023-10-16
Sky Biscuit
Sean-bumble-bee Posted at 10-16 12:09
https://store.dji.com/uk/product/dji-mini-3-pro-two-way-charging-hub?vid=114201
I checked a lot of places, but it didn't occur to me to check there. Thank you!
2023-10-16
Sky Biscuit
DJI Diana Posted at 10-16 13:22
Great! Thank you so much.
2023-10-16
DJI Diana
Sky Biscuit Posted at 10-16 13:52
Happy to help! Please feel free to reach us anytime. Cheers!
2023-10-16
