snowstorm
Flight distance : 467831 ft
Yes it does. The M3T says "sun detected, closing shutter" or something similar.
I was flying it today and left IR mode on and was swinging it around in the afternoon and the sun panned across the view. Note that it still left a burn-in mark on the sensor, where there is trail a spot that measures colder than the other areas. It seem to be temporary though, and went away after a few hours. It is still scary. I think it would be bad if it happens too long. I would be very careful using IR in the daylight. I am curious to know that if the shutter remains shut until IR mode is engaged, it must or it would be very problematic.
Be careful using IR mode in the day, sadly, that's when the vast majority of my flights take place. Watch where the sun is, avoid that direction and turn IR mode off as soon as you are done. |
