DJI Paladin
Hi there. Thank you for reaching out. The timecode function for the DJI Pocket 3 is similar to the one with Osmo Action 3 and 4. You are able to get access to the time code function under the system settings, for the timecode usage, you are advised to use a third-party timecode synchronizer to sync devices from different directions then the timecode will now be synchronized. When using the TentacleSync Timecoder with the unit, you only need to use the synchronization function of the "Timecoder”. The synchronization function is used to synchronize a separate timecode in the product, and after the synchronization is completed, the Timecoder can be unplugged. Hope this helps. Feel free to contact us if you have other inquiries. Thank you for your valued support. |
