Why does my Mavic Air suddenly go above 400 feet?
487 5 2023-10-28
Bluehook
Flight distance : 790814 ft
It never used to.  It would stop dead at 400.  Granted, I haven't tried to go above 400 ft is quite a while, so I don't knoiw when this change took place.
I checked: Max alt on the DJI GO app is still set at 400 on the "main" screen.  I do recal there is another setting for it somewhere else with a slider - not sure if that matters cause I didn't change anything...
Thanks for any insight, I appreciate any help.
2023-10-28
Sean-bumble-bee
Flight distance : 15997 ft
"is still set at 400 " 400 what, ft or m, have you checked?
Post a flight log, instructions can be found https://www.phantomhelp.com/logviewer/upload/
2023-10-28
Bluehook
Sean-bumble-bee Posted at 10-28 10:08
Thanks Sean - I'll check but the question would remain, "why did it change?"
I' don't wanna post a flight log but I appreciate your response.
Thank you!
2023-10-28
Sean-bumble-bee
Bluehook Posted at 10-28 12:43
Why might it have changed?  An accidental/unintended change on your part perhaps ?
"I' don't wanna post a flight log but I appreciate your response."
OK but upload the flight log to that site then down load the csv, unzip it and open it and look for the column entitled "HOME.heightLimit [ft]", that column contains the max height limit setting.
If it was 400ft and the drone went higher then there is a problem with the drone
2023-10-28
Labroides
Flight distance : 9991457 ft
Make up your mind.
You want to answer your question, or you don't want to post the recorded data that would hold the answer to your question.
Which is it?
You can't have both.
2023-10-28
Bluehook
Labroides Posted at 10-28 14:52
I understand your point and you're 100 percent correct.
I guess I was looking for a light discussion about this conundrum and don't have a real desire to dig into it too deep because it doesn't seem like an existential issue for the drone  - and again, I appreciate your response.
2023-10-29
