wombatomba
Flight distance : 89288 ft
FYI, when I was on chat with DJI support today, I got the following not-very-helpful statement about 3 possible scenarios (none of which answered my question):
1. For those ones who has removed the C0 label in 2023, there is only one chance to have C1 label.
2. For those ones who do not remove the C0 label in 2023, there will be chances to keep the C0 label with the 120m restriction, and chances to apply for C1 label after 2024 (while the prcedure TBC).
3. For those ones who purchase Mini 4 Pro in 2024, there will be non-removable mandatory category identification label. But, this model supports to apply for C1 and flying more than 120m in 2024.
Also, the similarly ambiguous:
As for now, you can request removal/declassification when you fly on EASA in 2023. As for 2024, will update you on the DJI Newsroom.
It seems that although the EASA regulations (and Ian and other YouTuber's videos) seem to be clear, that removing the C0 classification results in a 2023 Mini 4 Pro becoming a sub-250g "legacy" drone, DJI don't seem to be able to answer the simple question of whether those who purchased (and perhaps activated) their Mini 4 Pro during 2023 will still be able to declassify during 2024 (when they are located inside EASA region).
The DJI support person said they would personally write to the "relevant team" to get an answer; I suggested they should update their blog post, to clarify/confirm the current wording which states that those who purchased in 2023 should be able to declassify during 2024. |
