Loose motor RS3
571 5 2023-11-22
fanscbbb565a
Puerto Rico
Hello, recently someone bumped into me and my rotating motor is now loose? The ronin doesn’t lock or allow me to balance properly since it’s loose and when the camera is sitting on it, it creates friction on the rotating motor. The ronin is only 5 months old… Compared to my Dji  ronin S with 3+ years of usage and still works like a charm I am kinda disappointed with this situation. I hope I can somehow tighten the motor or something. Any work arounds ?
2023-11-22
DJI Susan
Hi there, I am sorry to hear about the issue you encountered with your RS 3. Would you please send a video of the loosened motor issue for better confirmation? If the unit experienced an external impact, you may consider sending the gimbal back to us for further check and service.
If needed, please contact our support at http://www.dji.com/support to start a case.
2023-11-23
fanscbbb565a
Puerto Rico
DJI Susan Posted at 11-23 00:32
Here is the issue I have https://fromsmash.com/RtOZbhjck_-et  , the thing is that I don’t have time to be sending Ronin’s over since I work as a videographer full time
If there is anyway to fix this myself i’m willing to try it out
2023-11-23
DJI Thor
Flight distance : 13602 ft
fanscbbb565a Posted at 11-23 07:04
Thank you for the video sharing. We forwarded to our engineer team to further check first.
2023-11-23
tcastro29
Hi, has a solution been made for this. I have had to buy a specialty kit to repair and retighten the screws and have been having to do this monthly with mine as well.
6-5 10:32
DJI Susan
tcastro29 Posted at 6-5 10:32
Hi there, we are sorry for the issue you are encountering. Could you please provide a video showing the issue? You may save it through a shareable link like Google Drive and DropBox, then send the link here. We will check this further for you.
6-5 20:25
