geoff.kline
Here are the logs. If i look on the flight App it is reporting the latest 1.4.001 as the firmware version. Not sure if that normal with a failed upgrade.
[00014231][01 00] Firmware upgrade finished successfully.
[00014338]Done.
[00014367]Packet [C:\P3X_FW_V01.04.0010.bin] resumed, card sn [0x50ce3539].
[00014401]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014467]Version checking[2]...
[00014533][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00014592][03 06][00] v2.1.6.18 -> v2.3.0.13 need upgrade.
[00014644][04 00][00] v1.36.0.0 -> v1.41.0.0 need upgrade.
[00014691][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014792][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00014885][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014968][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015042][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015135][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00027668][15 00][00] device not detected.
[00027737][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00027867][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00027913][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027943][01 00][05] v1.23.3419 -> v1.23.3419
[00027971][01 01][00] v1.6.2736 -> v1.23.3419 need upgrade
[00040503][08 00][00] device not detected.
[00040533]Done.
[00040563]Firmware upgrading[2]...
[00040705][01 01] Firmware upgrade start...
[00070964][01 01] Firmware upgrade finished successfully.
[00071007][12 00] Firmware upgrade start...
[00135169][12 00] Firmware upgrade finished successfully.
[00135213][12 01] Firmware upgrade start...
[00201586][12 01] Firmware upgrade finished successfully.
[00201630][12 02] Firmware upgrade start...
[00264809][12 02] Firmware upgrade finished successfully.
[00264855][12 03] Firmware upgrade start...
[00332358][12 03] Firmware upgrade finished successfully.
[00332411][17 00] Firmware upgrade start...
[00469100][17 00] Firmware upgrade finished successfully.
[00469140][17 01] Firmware upgrade start...
[00553567][17 01] Firmware upgrade finished successfully.
[00553606][11 00] Firmware upgrade start...
[00603300][11 00] Firmware upgrade finished successfully.
[00603343][03 05] Firmware upgrade start...
[00677425][03 05] Firmware upgrade finished successfully.
[00677652][03 06] Firmware upgrade start...
[00994583][03 06] Firmware upgrade finished successfully.
[00994648][04 00] Firmware upgrade start...
[01052257][04 00] Firmware upgrade finished successfully.
[01052288]Done.
[01052320]Version checking[3]...
[01052390][03 05][05] v34.2.0.9 -> v34.2.0.9
[01052471][03 06][05] v2.3.0.13 -> v2.3.0.13
[01052505][04 00][05] v1.41.0.0 -> v1.41.0.0
[01052550][09 00][00] v1.7.0.3 -> v1.7.0.3
[01052650][11 00][05] v1.7.0.0 -> v1.7.0.0
[01052724][12 00][05] v1.10.0.0 -> v1.10.0.0
[01052805][12 01][05] v1.10.0.0 -> v1.10.0.0
[01052904][12 02][05] v1.10.0.0 -> v1.10.0.0
[01052979][12 03][05] v1.10.0.0 -> v1.10.0.0
[01065513][15 00][00] device not detected.
[01065600][17 00][05] v1.1.1.7 -> v1.1.1.7
[01065720][17 01][05] v1.0.2.7 -> v1.0.2.7
[01065771][19 00][00] v1.0.8.96 -> v1.0.8.96
[01065802][01 00][05] v1.23.3419 -> v1.23.3419
[01065834][01 01][05] v1.23.3419 -> v1.23.3419
[01078364][08 00][00] device not detected.
[01078397]Packet upgrade failed at version checking.
[00015472]========== remo-con disconnect. boot(15) ============
[00015580]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x50ce3539].
[00015682]Packet upgrade start...
[00015832]Packet checking...
[00015934]Packet vlink 01.04.0010 <-> 01.03.0020.
[00016036]Done.
[00016093]Version checking[1]...
[00016163][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016227][03 06][00] v2.3.0.13 -> v2.3.0.13
[00016265][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016312][09 00][00] v1.7.0.3 -> v1.7.0.3
[00016442][11 00][00] v1.7.0.0 -> v1.7.0.0
[00016516][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016607][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016682][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016756][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029286][15 00][00] device not detected.
[00029352][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029452][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029491][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029614][01 00][00] v1.23.3419 -> v1.23.3419
[00029645][01 01][00] v1.23.3419 -> v1.23.3419
[00042177][08 00][00] device not detected.
[00042208]Packet upgrade failed at version checking.
[00014612]========== remo-con disconnect. boot(15) ============
[00014650]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x50ce3539].
[00014681]Packet upgrade start...
[00014717]Packet checking...
[00014752]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014815]Done.
[00014848]Version checking[1]...
[00014912][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014987][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015026][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015081][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015167][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015244][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015333][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015406][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015506][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028037][15 00][00] device not detected.
[00028096][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028196][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028262][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028295][01 00][00] v1.23.3419 -> v1.23.3419
[00028333][01 01][00] v1.23.3419 -> v1.23.3419
[00040867][08 00][00] device not detected.
[00040900]Packet upgrade failed at version checking.
[00014469]========== remo-con disconnect. boot(15) ============
[00014500]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x50ce3539].
[00014531]Packet upgrade start...
[00014568]Packet checking...
[00014599]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014670]Done.
[00014698]Version checking[1]...
[00014768][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014828][03 06][00] v2.3.0.13 -> v2.3.0.13
[00014869][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014917][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015028][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015097][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015177][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015261][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015396][12 03][00] v1.10.0.0 -> v1.10.0.0
[00027930][15 00][00] device not detected.
[00028020][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028139][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028198][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028237][01 00][00] v1.23.3419 -> v1.23.3419
[00028272][01 01][00] v1.23.3419 -> v1.23.3419
[00040810][08 00][00] device not detected.
[00040845]Packet upgrade failed at version checking.
[00014721]========== 2015.09.07 10:04:23. boot(15) ============
[00014755]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x50ce3539].
[00014788]Packet upgrade start...
[00014828]Packet checking...
[00014862]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014928]Done.
[00014961]Version checking[1]...
[00015035][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015089][03 06][00] v2.3.0.13 -> v2.3.0.13
[00015130][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015183][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015291][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015364][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015446][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015542][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015623][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028157][15 00][00] device not detected.
[00028240][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028343][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028403][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028437][01 00][00] v1.23.3419 -> v1.23.3419
[00028473][01 01][00] v1.23.3419 -> v1.23.3419
[00041005][08 00][00] device not detected.
[00041041]Packet upgrade failed at version checking.
[00014492]========== remo-con disconnect. boot(15) ============
[00014530]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x50ce3539].
[00014565]Packet upgrade start...
[00014612]Packet checking...
[00014650]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014717]Done.
[00014753]Version checking[1]...
[00014820][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014879][03 06][00] v2.3.0.13 -> v2.3.0.13
[00014924][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014990][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015179][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015249][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015341][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015414][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015494][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028033][15 00][00] device not detected.
[00028104][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028235][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028292][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028331][01 00][00] v1.23.3419 -> v1.23.3419
[00028368][01 01][00] v1.23.3419 -> v1.23.3419
[00040904][08 00][00] device not detected.
[00040940]Packet upgrade failed at version checking. |
