Serg SSA
Flight distance : 6406329 ft
Russia
Manitobahunter Posted at 12-28 23:37
I do it as much as land on a pad. As I said above, I hold my arm outstretched above my head, flat palm facing up with the drone a hovering a half meter over my hand. I hold the left control stick down, and the drone will start to decend after a moment or two. I hold my hand still until it starts its landing sequence, and then when it gets close to my hand, I quickly pinch the little drone by the sides of the belly between my thumb and index fingers, while keeping the left stick held down, I hold still till the motors turn of, no need to flip it upside down and make it try to escape. I do this in normal mode, and never have an issue, not sure why you are. I did the same thing with my mini 3 pro. Only thing I can think of is I hold my arm and hand up above my head so that I'm not an obstacle to avoid, are you doing that?
I land mini 1-3 and mavic 2 and DJI FPV on my hand))) without problems, I know all the nuances. The sensors on none of the drones prevented me from landing. I also land the Mini 4 in front of me, I haven’t tried it above my head. Mini 4 behaves differently from other drones when landing. |
