Error Fly Safe
758 8 1-2 16:02
djiuser_3NGqW0mAD4Tf
Flight distance : 63189 ft
After update fail safe error
161000AB
any ideas?
1-2 16:02
DJI Gamora
Hi, there. Thank you for reaching out. Please connect your DJI RC to your network and update the Flysafe database via the DJI Fly app. “Settings - About”. I hope this information helps.
1-2 21:44
djiuser_A3JQh8cEFwlj
Flight distance : 8842 ft
Switzerland
hi from Switzerland
I got the same error today after requesting a change in Altitude limit.
Ticket pending
Fly Safe database error.
i cannot update anymore
Network is OK.
1-3 03:57
digital-stc
Switzerland
I saw your message in the thread that I started. https://forum.dji.com/forum.php?mod=viewthread&tid=304610. I am from Switzerland too. Did you file a ticket for the FlySafe update problem with the support?
1-3 04:22
digital-stc
Switzerland
I saw your message in the thread that I started. https://forum.dji.com/forum.php?mod=viewthread&tid=304610. I am from Switzerland too. Did you file a ticket for the FlySafe update problem with the support? I was requested to submit logfiles, but I don't know how to upload them.
1-3 04:24
ROBE di DRONI Srls
Flight distance : 27047326 ft
Same here, dji mini 4 pro updated to 01.00.0300 fw and now I can't fly anymore... error code 161000AA and 161000AB.
Mini 4 and DJI RC 2 firmware reset done via DJI Assistant but errors are still there and no way to take off..
1-3 07:21
djiuser_NhNahH54LQVB
Buonasera
Dall'italiano stesso problema.
Aggiornato il drone con tutte e tre le batterie. Aggiornamento firmware fly mi dice che errore server e non mi fa volare.
Stessi codici di errore
1-3 12:27
DJI Susan
Hi there, we are sorry for the inconvenience caused. Our engineers are aware of the issue and will optimize it soon via the update of the fly safe database. Please wait for the update. Apologize for the inconvenience and we appreciate your patience.
1-4 01:34
DJI Susan
djiuser_A3JQh8cEFwlj Posted at 1-3 03:57
hi from Switzerland
Ticket pending
Hi there, there is an update for the flysafe database, could you please update it and check if the issue is solved?
1-4 19:10
