Not able to update Firmware Mini 3 Pro.
803 11 1-3 09:04
trawest
Flight distance : 363593 ft
I am experiencing problems in updating the firmware for my Mini 3 Pro.  Each time I try it comes back with server error plaese try agin in a few minutes.  This has been going on for days.
Current firmware 01.00.0400
Would you confirm as to whether there is a server problem or not.  If not how can I update the firmware for my drone??
I await your response.
Thank you.
1-3 09:04
DowntownRDB
Flight distance : 1722 ft
I had a similar issue once.  I signed out of my DJI Account and then back in.  I downloaded the DJI Assistant 2 and then tried to update the firmware. Errored out again.  So then I tried and succeeded in updating using the data on my smartphone.  Not sure what the issue was with my wifi as subsequent firmware updates have worked via that same wifi.  If you need DJI Assistant 2 for the Mini 3 Pro you can download it here.  Latest version is V2.1.20    Hope this helps resolve your issue.
https://www.dji.com/downloads/so ... sumer-drones-series
1-3 12:36
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we do apologize for the trouble. Please download the DJI Assistant 2 software on your computer to update your drone and remote controller. You may download the correct version of the software using the link below. Hope this helps.
1-3 23:26
warloc59
Flight distance : 209160 ft
DJI Paladin Posted at 1-3 23:26
https://www.dji.com/downloads/softwares/dji-assistant-2-consumer-drones-series
How about DJI just fix the problem?  So what dji is saying if you’re away from your computer, you are absolutely screwed. Just fix the problem dji!  What’s the problem?  Getting really tired of this Que card support from dji.
1-4 05:40
Hoarfrost
Flight distance : 705974 ft
The few times this happened to me I deleted the cache and then rechecked for updates. Sometimes, an error in the first attempt at a firmware update is interrupted which then compromises further attempts.
1-4 07:06
trawest
Hi,
I did as you posted to me .......and it worked.
Thank you very much.  Problem solved.
1-4 07:11
trawest
DowntownRDB Posted at 1-3 12:36
Hi, DJI Paladin came up with the resolve and all well.
Thanks for your input.
1-4 07:12
trawest
Hi,
Yes I downloaded DJI Assistant 2 and downloaded the firmware/software and all is tickity boo.
Thanks for your help.
1-4 07:16
DowntownRDB
trawest Posted at 1-4 07:16
Hi,
Glad I could help.  Happy flying.
1-4 14:37
trawest
DowntownRDB Posted at 1-4 14:37
Thank you, and happy flying to you also.
1-4 15:19
DJI Paladin
warloc59 Posted at 1-4 05:40
Hi there. Thank you for reaching out and we're sorry if you are having issues with your unit. Can you please confirm if you also experienced the said issue? Please provide us with the exact drone and remote controller you are using with a screenshot showing the error for us to check it further. We will surely provide you with relevant information after receiving the information needed. We appreciate your understanding and support.
1-5 02:51
DJI Paladin
trawest Posted at 1-4 07:11
Hi,
We appreciate your response and we're glad that you managed to isolate the issue you experienced. Should you have other inquiries or concerns, feel free to contact us. We are more than happy to help. Thank you for your valued support!
1-5 02:52
