dji code 30166 motor inactivo
305 3 1-31 19:33
djiuser_v65qBmoqgrQc
Flight distance : 139987 ft
Colombia
dji code 30166  motor inactivo. Compruebe que las helices se hayan instalado... alguien le a pasado y cual es la solución  gracias
1-31 19:33
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Can you please confirm what specific drone are you currently using? Did you experience a hard landing using this unit before? Please keep us posted.
1-31 20:35
Colombia
Si sr@ es dji mini 2 se  no señor solo lo eleve a 500  y despues varias tomas aparecio el error lo puedo seguir utilizando asi o que debo hacer ? Pues las elices motores estan bien
1-31 20:45
DJI Gamora
djiuser_v65qBmoqgrQc Posted at 1-31 20:45
Thank you for responding. The error code refers to the motor idling. Please check whether the propellers have been installed. You may consider replacing all the propellers if they have been installed correctly for further testing. I hope this information helps. Thank you for your support.
2-2 03:02
