osmonauta
Hungary
Some people posted footage where the camera is inside a car and when the car is turning at high speeds, the entire image is tilted and takes a while until it straightens out due to the gyroscope not doing something right.
I wonder if this might be something similar. Watch the bike when this happens. You can see this better if you focus on the windshield. The bike is quickly bouncing up and down when this effect takes place. If the bike doesn't bounce that much, it's ok. So maybe it has to do with, again, the gyroscope as you are going at high speed, and the bike bounces more than a certain amount.
What if you go slower, say, keep it on 40 or 30. Will it happen? Also try different mounting options, eg helmet/handelbar combined with reduced speed and see if it shows up.
It would be helpful if someone who has a bike and an OA4 would try this so you guys could compare the result.
