DJI Mavic Mini max altitude
222 3 2-29 23:13
DroneNewbie88
Singapore
Hi,
I tried to fly a Mavic Mini but seems the max height like less than 10-15m, and I cannot fly above this altitude even though I have set my max altitude 30m.
I am trying to fly indoor, does this affect the max altitude (since there is no GPS?).
What is the max altitude for Mavic Mini? Thanks.
2-29 23:13
DAFlys
No GPS signal will limit the max altitude you can fly at.
3-1 02:32
DJI Gamora
Hi, DroneNewbie88. Thank you for reaching out. The Maximum Takeoff Altitude of the Mavic Mini is 3000 m. Do not use the aircraft in a poorly lit environment without GPS signals (such as at night or in a dark indoor corner). The aircraft may drift when flying or may not hover when flying in these environments. It is recommended to use the aircraft in a well-lit environment with strong GPS signals. If the GPS signal is strong, the aircraft can take off and default restrictions are not triggered.
3-1 03:24
AlexBacki
Ukraine
thanks!! not bad
3-8 07:45
