Mini 2 connection issues!
692 26 3-8 11:26
nmb1970
Flight distance : 169990 ft
Portugal
Hello there!
I’ve been using my mini2 for 2 years without an issue but I haven’t been flying for a while.
Two weeks ago I needed to record an event and powered on the system to check for updates before.
RC Controller had an update and I made it.
First thing weird was with the controller and drone side by side on a table, connection was poor. Checked frequency and only was poor on 5GHz. 2.4 was perfect. Not good but I was thinking maybe the crowded wifi network on the neighborhood was the reason.
On the event I fired the drone and seemed to work fine until…
I was very close to the drone and was getting disconnection issues. two or three times I was getting closer to regain connection but the issue continue so I cease to use it.
I uploaded the log so if anyone can light some reason on this happening…
Thanks!
3-8 11:26
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we do apologize for the trouble. Please download the DJI Assistant 2 software on your computer and update/refresh the firmware of the aircraft and remote controller. It is also recommended to update the app to the latest version to avoid any unknown issues. After doing the updates or refreshing the firmware (if you are using the latest), have a test flight in different to see if the issue persists. You may start a screen recording during the test flight so you can send it to us after if you experience any sudden behavior. Please keep us posted. We appreciate your cooperation.
DJI Assistant 2 software: https://www.dji.com/global/downl ... sumer-drones-series
3-8 23:29
nmb1970
Portugal
DJI Paladin Posted at 3-8 23:29
DJI Assistant 2 software: https://www.dji.com/global/downloads/softwares/dji-assistant-2-consumer-drones-series
Ok. Already tried changing firmware from the latest to the previous both on drone and controller.
It looks like 5.8GHz mode has die on the last update and nothing gets it back.
Now what to do?
3-10 04:08
yogi053
Flight distance : 26104915 ft
Did your updates take long to complete. There have been recorded cases in the past where people have experienced their 5.8ghz chips appearing to burn out whilst carrying out updates through overheating. I always stick my Minis in the fridge when doing any updates. So far, so good. I would be interested in the solution if any is found.
3-10 04:33
nmb1970
Portugal
yogi053 Posted at 3-10 04:33
updates were fast. since then tried downgrading with dji assistant and upgrading and nothing.
putting in the freezer? seems like overkill to me. but also these days are a bit chilly anyway...
3-10 04:38
yogi053
nmb1970 Posted at 3-10 04:38
NOT in the freezer but in the fridge. If you search,there are a number of threads where it seems very likely that updates were taking quite long resulting in the Mini 2s having connection problems with the drone on 5.8ghz frequency but being ok on 2.4ghz frequency. I was only trying to point you to those threads. Sorry for your troubles.
3-10 04:42
nmb1970
Portugal
yogi053 Posted at 3-10 04:42
I meant fridge. sorry.
too bad I didn't read those threads
3-10 04:44
DJI Paladin
nmb1970 Posted at 3-10 04:08
Thank you for your response, nmb. Have you tried to do a test flight away from your current flight area to isolate the issue further? Also, please confirm if the issue only appears on the 5.8Ghz and if there is no issue if you select 2.4Ghz or Dual band. Please keep us posted. I appreciate your cooperation.
3-10 22:05
nmb1970
Portugal
DJI Paladin Posted at 3-10 22:05
Hello!
Today tried a simple flight and even on the ground next to the drone manual selecting 5.8GHz has almost no signal.
I captured the phone screen:
please advise
3-16 14:20
yogi053
nmb1970 Posted at 3-16 14:20
Hello!
That is a very good video clip exactly showing the problem you have on your drone. Dji should sit up and take notice of this 5.8ghz problem and issue a warning about having to take precauions to keep ALL drones cool whilst carrying out any updates. In fact carrying out updates on any equipment not fitted with cooling fans. The Mini 2 may be near end of life (no more production I believe), but if there are any further updates (highly unlikely), i will continue to stick the equipment in the fridge whilst doing them.
edit:- If I do upgrade to Mini 3 Pro or the 4, I will do the same. Can it do any harm for the length of time that it takes?
3-17 01:42
DJI Paladin
Hello!
Thank you for the information provided. We will now coordinate this with our relevant team for further clarification. We will surely keep you posted once we receive an update. We appreciate your patience.
3-18 01:45
DJI Paladin
Thank you for patiently waiting. If the signal is disconnected or no signal when manually switched to 5.8GHz band, that means the current test environment has relatively large interference in the 5.8GHz frequency band. It is recommended to use the Dual-Band and "Auto mode". This mode does not require you to judge the interference degree of the frequency band and channel, and will automatically help you choose the frequency band and channel with the least interference.
3-20 22:22
nmb1970
Portugal
DJI Paladin Posted at 3-20 22:22
Wrong. In dual mode as you can see in the video, the drone chooses 5.8 and fails. I have to manual switch to 2.4 to even use it.
3-20 23:30
DJI Paladin
nmb1970 Posted at 3-20 23:30
Thank you for your response. Please provide us with the following for further investigation:
1. Flight controller log (aircraft log), remote controller log, APP log (and need to provide the specific date and time when the problem occurred);
2. Customer's country & specific location.
You may upload the files via Google Drive and send the link here so we can check it further. Please keep us posted.
3-22 22:03
nmb1970
Portugal
DJI Paladin Posted at 3-22 22:03
Hello,
I got several files from my iPhone and uploaded to google drive at
https://drive.google.com/file/d/ ... k-/view?usp=sharing
This was the last flight at 2024/03/16 around 5PM
I'm from Portugal and was at:
https://maps.app.goo.gl/F7kGczd5rqmPLSKZ8
If you need other files you need to tell me how to get them.
Thanks,
Nuno
3-30 08:26
DJI Paladin
nmb1970 Posted at 3-30 08:26
Hello,
Thank you for the information provided, nmb1970. We will now forward this to the relevant team for further investigation. We will keep you posted.
3-30 20:39
djiuser_zhcXOLdDLjiP
India
Hi, I have the same issue with my mini 2 drone after updating it last week. I had been flying this drone for more than 3 years with no issues. but after the update last week to below versions, the aircraft disconnect with RC and returns home within few meters away. It is so frustrating. I just updated the firmware before going on a family Vacation to have some nice shots and it ruined the plan. I almost crashed the drone in sea twice. I just flew the drone 3 times and all the three times same issue happened and now I am afraid to fly it again.
Aircraft Firmware 01.07.0200
RC Firmware 04.11.0400
App Version 1.12.8
Reading all the threads I see that it is a universal complaint of the 5.8 Ghz chip burning out during update causing this issue. We are just looking for DJI to acknowledge if this can be fixed or not so that we dont spend our valuable time hoping for a solution or a fix and waste time waiting and investigating on this. I think atleast DJI can save customers time by confiming this issue.
When thousands of your customers are reporting the same issue after update, how can it be not true? and why dont you give any official statement on this? Even if you are not going to recall or provide a fix an official statement will give peace of mind to your customers and increase their trust on you. By not acknowledging the issue, DJI is just going to loose the trust and love that DJI had accumulated from its customers all these years.
3-30 21:05
DJI Paladin
Hello,
Hello there. Upon checking the files you sent, it seems that the files are invalid. You may follow the steps I posted on this THREAD under post #18 on how to export the aircraft log and App log. To export the remote controller log, the process is the same as exporting the aircraft log, just connect your controller via DJI Assistant 2 software and go to "Log Export". Please keep us posted.
4-1 00:57
nmb1970
Portugal
DJI Paladin Posted at 4-1 00:57
OK!
New file with logs exported from DA2 and logs folder from the iOS Fly App
https://drive.google.com/file/d/ ... Ix/view?usp=sharing
Best regards,
Nuno
4-1 11:30
DJI Paladin
nmb1970 Posted at 4-1 11:30
OK!
Thank you for the information provided. We'll check if this will work. I will update you once we receive a response. We appreciate your cooperation.
4-4 00:06
DJI Paladin
Thank you for patiently waiting. Upon checking here, it shows that the signal strength in the 5.8g frequency band on your location is weak. We suggest changing the environment to eliminate the interference factors of the environment to the specific frequency band. If the issue persists, the issue might caused by a hardware malfunction and it is recommended to send it in for testing and confirmation. You may contact our team at https://www.dji.com/support for you to start a ticket case. We appreciate your understanding and support.
4-8 02:57
oolsson7
Flight distance : 34364 ft
Sweden
The same for me each time it lose connection and also in close distance like 10-15 meter... nerver had this issue before.And it not started the return home even... it just froze (2 min) and nothing happen until it connect again.
4-22 04:39
fansa88554cb
Sweden
When I use DJI assist I only see the latest firmware, I could not see older version or previous version ?
4-24 04:59
DJI Paladin
fansa88554cb Posted at 4-24 04:59
Hi there. Thank you for reaching out. Are you using the DJI Mini 2 aircraft? If yes, regretfully, we don't have an option to downgrade the firmware with the DJI Mini 2 drone. We appreciate your understanding and support.
4-25 20:51
fansa88554cb
Sweden
I made refresh of all firmware to the latest with the software , and then today I made a test again.
But same issue about 2-3 min in flight it lose connection, nothing happens it not even start the return to home it just stand still.
After 1 to 1,5 min it connect again and I manual return it to ground again, the same each time about 2- 3min in flight it lose.
But I just landed and then I made a lift off and went up about 20 21 meters and made made 30 meter flight away from me .. all was ok to 25 % left of battery.
And no lost connection.. and this is also exactly the same behavior as before.
Sorry I did not made any screen record of this but I think I could download log from my drone and send it to you if you like ?
My plan was to take it with me on my trip for 2 weeks but not now when it not working as it should.
I need to say the product is great and has be working 100% until the last firmware upgrade, and things happen that is the way it is so I hope some ide what cause this will be fund so it could be fixed.
Futher on I will upgrade to Mini 4 pro or what is available but just now I hope to get this solved.
Thanks a lot .. Kind regards/Ola
4-29 10:10
Sean-bumble-bee
Flight distance : 15997 ft
What controller are you using?
That it did not RTH suggests to me that either your phone disconnected or somehow the screen disconnected. but just to be on the safe side check that the "failsafe" setting is RTH and not hover.
You might also like to upload the .txt flightlog from the phone or controller to
https://www.phantomhelp.com/LogViewer/Upload/
then post the resulting URL here.
4-29 11:30
fansa88554cb
Sweden
Sean-bumble-bee Posted at 4-29 11:30
Yes I will try to do this by tomorrow 2024-05-02  ..short of time pack for my travel.
Maybe I get some time later today.. hope to manage, If not I will be back 2024-05-18.
Then I need to say Thanks for your service..
Kind regards Ola
5-1 09:47
