A cautionary tale about one resellers attempt at content creation. I attempted to document the T30 in use in one of our hillside olive orchards by using an Air 2s in Active Tracking mode.
For background, after the T30 was powered on, the Air 2s was initiated and flown to about to about 1.5-2m AGL. Once I locked on to the T30 with the Air2s's Active tracking mode, I put down the Air 2s RC and exchanged it for the Agras RC. This was done for two reason, first to initiate flight and secondly when the T30 is in close proximity (<3 meters) to trees, at a height of about 2-4 meters it warns of an overhead obstacle and commences to brake. At which point you must manually raise the unit above the tree line, jiggle the right joystick and press "continue" mission on the RC screen. So, the following ensued as soon as the T30 flight was initiated:
For some inexplicable reason the Air 2s kamikazied into the T30.
The resulting damage:
Air 2s:
T30:
Although the propellers of the T30 sustained considerable damage the unit remained in the air displaying only a slight vibration.
