Dji needs to fix barometer issues, else there might be illegal drone flying
242 6 4-4 03:35
djiuser_elmIyQiglT87
Flight distance : 6091768 ft
Romania
https://youtu.be/NjugkRWd34w?si=sWVxDwI-xbtdSXvP
4-4 03:35
DJI Diana
Flight distance : 2408 ft
Hello, djiuser_elmIyQiglT87. I've viewed the video and I regret to hear about the problem. Can you confirm whether your drone crashed or got lost? Did you notice any errors before your flight? We are eager to receive your response.
4-4 10:15
Romania
DJI Diana Posted at 4-4 10:15
This happened over 1 year ago and i got a replacement for it. The drone was lost sience it climbed 3 times over the 500m and fell out of the sky bc of low battery.
I dont need help with anything, im just saying there should be some kind of barometer calibration or something, because i got this issue on a lot of different drones. Thanks
4-4 19:52
DJI Diana
djiuser_elmIyQiglT87 Posted at 4-4 19:52
Thank you for your response, and I'm sorry to hear about your experience with the drone. It's unfortunate that you've encountered similar issues with different drones. May I ask if you tried to calibrate the IMU of your drone before this happened?
4-5 14:48
Romania
DJI Diana Posted at 4-5 14:48
Yes ive tried to calibrate imu and compass but nothing.
The drone keeps flying all over the place with the error message "No pozition" and "Gps signal weak" or sometimes it just randomly starts flying away and drops out of the sky with the error "Restart Aircraft"
This is worse than a normal flyaway, because the drone doesnt have vertical/horizontal pozition  and it will start ascending at max power load while it is blown away by the wind. It is most likely a barometer issue, because before the drone enters ATTI mode it climbs for a few seconds at max power load in gps mode then the wind blows it away while climbing. I found out that the reason it exits gps mode is because the drone is thinking that its falling and the barometer shows falling with 30m/s or more. And the drone is climbing until it runs out of battery or falls out of the sky.
There are some links to these flyaways:
https://youtu.be/QU47wcolgGA?si=Jo9U7BIFml9FoDBs
https://youtu.be/dxPqmbtUsw4?si=UZiHnYFFVKAlhPEj
+ comment
4-5 20:47
Romania
djiuser_elmIyQiglT87 Posted at 4-5 20:47
https://youtu.be/Nj9oIrsB9hE?si=_YjjdrqLGK62cJLJ
https://youtu.be/T5gnZWcPGbU?si=OzgtV6aRJzm1krJh
https://youtube.com/shorts/6PPIDibK5ok?si=Sbyw5IuslS5-aMxN
4-5 20:49
DJI Susan
djiuser_elmIyQiglT87 Posted at 4-5 20:49
Hi there, we are sorry for any inconvenience. You could complete the online repair request on our official website and return it for further diagnosis. Here is the link: https://repair.dji.com/gb/repair/index
4-5 22:23
