DJI Support
Flight distance : 2408 ft
Overview
- Date:2024.04.09
- DJI Focus Pro LiDAR Firmware:v01.01.0500
- DJI Focus Pro Grip Firmware:v01.01.0500
- DJI Focus Pro Hand Unit Firmware:v01.01.0500
- DJI Ronin App iOS:v1.7.0
- DJI Ronin App Android:v1.7.0
- DJI Assistant 2 (Ronin Series): v2.1.11
- User Manual:v1.0
What’s New
- Added support for adding up to 15 group lens profiles.
- Added focus pull for supported camera lenses after connecting the grip with Bluetooth or a cable when the front dial of the grip is set to focus (F motor is not connected.)
- Added electronic zoom control for supported camera lenses after connecting the grip with Bluetooth or a cable when the front dial of the grip is set to zoom (Z motor is not connected.)
- Added autofocus when using grip with DJI RS Focus Motor (2022) and DJI LiDAR Range Finder (RS).
- Added prompts when the battery voltage of the grip is abnormal.
- Added connection status display when the hand unit is connected with Ronin 4D or Inspire 3.
- Improved auto focus experience.
- Optimized car detection.
- Improved the distance measurement stability in scenarios such as backlight or mirror reflection.
Notes:
- Make sure that the DJI Ronin app is the latest version when updating the firmware.
- Update the firmware of the LiDAR using the DJI Assistant 2 (Ronin Series). Do not disconnect the LiDAR and the computer during the update process.
- Update the firmware of the grip/hand unit using the DJI Ronin app by connecting the grip/hand unit via Bluetooth. To update the motor, connect it to the grip or hand unit first, and then update the firmware via the grip or hand unit and the Ronin app. Do not disconnect the DJI Ronin app and the device during the update process.
- If the firmware update fails, restart the device and retry.
