Time-Lapse Videos: Auto vs Manual setting
219 4 4-11 08:08
OldScout
Pocket 3 - Capturing time-lapse
I've noticed on time-lapse vids of clouds and sunsets, it appears that there is an annoying "flicker" present that looks like subtle changes to Exposure and/or White Balance from frame to frame, suggesting that the Pocket 3 adjusts exposure and white balance for each individual frame. If I recall, I used all Automatic settings.
My question is this: when capturing time-lapse, does the Pocket 3  make constant adjustments during the capture for each frame, or does it set a static/fixed exposure and WB when the capture begins and sticks with that one setting for the duration of the time-lapse?
Do either Auto or Manual settings cause the Pocket 3 to make constant adjustments to Exposure/WB? How can I ensure that the settings are fixed for the duration of the time-lapse?
4-11 08:08
smbishop
Flight distance : 2454508 ft
I make a lot of timelapse and motionlapse videos.  I always use manual exposure, ISO, and set the white balance manually.  During a timelapse you can use the Mimo app to lock focus, but not with a motionlapse.  These settings work well for me.  I also export the DNG photos to process the video.
4-12 05:50
OldScout
smbishop Posted at 4-12 05:50
Thanks for your reply. I'm hoping you could clarify the comment about exporting DNG photos to process the video. Are you referring to normal timelapse capture? After I complete a time-lapse capture, I only see an MP4 file. What am I missing? Thanks...
4-12 05:58
DJI Tony
Hi, OldScout. Thank you for reaching out. I will forward this concern to the relevant team to check. Will it be fine if you share a video showing the issue? Thank you so much.
4-13 01:21
smbishop
OldScout Posted at 4-12 05:58
There is an option to save both a video and RAW when you swipe left in PRO mode...
4-13 03:20
