Bug discovered in DJI Avata 2
933 31 4-12 06:55
USER001
This person might have discovered a bug in his DJI Avata 2.
4-12 06:55
DowntownRDB
Flight distance : 1722 ft
I've watched it twice now and I'm thinking it is more of a glitch than a bug.
Beginner mode should be called turtle mode.
4-12 07:48
USER001
DowntownRDB Posted at 4-12 07:48
But then what will they call turtle mode? Do you know if the Avata 2 actually has turtle mode?
4-12 07:49
DowntownRDB
USER001 Posted at 4-12 07:49
That's a great question.  I doubt they would have removed it as it was a great feature.
4-12 08:42
USER001
DowntownRDB Posted at 4-12 08:42
I just saw a video. It's still there. Very useful if you crash on a tall roof or something and you can't manually retrieve it.
4-12 08:51
DowntownRDB
USER001 Posted at 4-12 08:51
Good to know that feature was not removed.
4-12 09:52
Elephant Apocalypse
Flight distance : 6336594 ft
Saw a review of someone actually testing for the tumble and sad to say, to an extent its still there, however it doesn't flat slip on its back like the old onlyfans.com/avatatumble did
4-12 10:50
Iczeman
Flight distance : 8429108 ft
Czechia
Exactly the same issue today with Avata 2 and first flight. It was super slow flight in beginner's mode and had to enable/disable it once more and several times unexpected stop with no response to motion controller. Following flights were ok without any issues. Latest firmwares updated before flight of course...
4-12 11:25
erutan
I came here wondering if it was my bug - I can't get past the "Press accelerator lightly to control aircraft orientation. Press and hold Lock button to land aircraft" stage.
I assume it's a bug in the unlocking logic of onboarding, the only button that works on the RC remote is the lock button, I've done hard trigger pulls, soft trigger pulls, backwards pulls, etc.  All the units talk to each other fine, and the RC control passes all the calibration checks.  It also operates normally in the AR/menu mode when the drone is locked so it doesn't seem like a hardware issue.
I've passed on logs + a video to DJI support. It's a shame there's no factory reset on the Drone I can trigger, it seems like that would kick me out of the busted tutorial onboarding (if that is what it is).
Can't post a new topic, so just adding this comment here.
4-12 13:00
USER001
erutan Posted at 4-12 13:00
You should contact one of the DJI Administrators through the Personal Message. That should help, because I don't know what you are talking about.
4-13 02:21
USER001
DowntownRDB Posted at 4-12 09:52
I once crashed my DJI Spark on my own roof while trying to fly through the window. If it had turtle mode I could have got it back immediately, but I had to put a wooden board on my window and wait a few days for Spark to roll down my roof and onto the board.
4-13 02:28
DowntownRDB
USER001 Posted at 4-13 02:28
That was a very creative way to "retrieve" the drone.
4-13 04:42
USER001
DowntownRDB Posted at 4-13 04:42
I didn't think of it. It was my friend's idea. Fortunately he is a quick thinker and he had the idea before the Spark slipped off the roof.
4-13 04:45
DowntownRDB
USER001 Posted at 4-13 04:45
Nice to have smart friends.
4-13 04:46
USER001
DowntownRDB Posted at 4-13 04:46
Always better than dumb friends
4-13 05:19
Elephant Apocalypse
Nice to have turtle mode on a cinewhoop; turtle mode on FPV drones almost always result in prop damage or more.  But ya, as long as you still have reception its a life saver from having to fetch your drone
4-13 05:40
DowntownRDB
USER001 Posted at 4-13 05:19
You're right about that.
4-13 05:48
erutan
USER001 Posted at 4-13 02:21
I had already talked to support, I was just wondering if this was a known issue or if there was some way around it.
The new firmware today solved it!  My gimbal is acting a little weird though.
4-13 18:57
USER001
erutan Posted at 4-13 18:57
Maybe you just need to do a quick calibration of the horizontal axis and it will correct it's position.
4-14 00:29
erutan
USER001 Posted at 4-14 00:29
Calibration normally hangs at 10% in the test, I got it to 60% once.
Seems like I'm not the only one: https://forum.dji.com/forum.php? ... 7&page=1#pid3289696
4-14 07:49
USER001
erutan Posted at 4-14 07:49
There are some YT videos on how to calibrate the Avata 2. You should check them out.
4-14 07:50
erutan
USER001 Posted at 4-14 07:50
I've done DJI's gimbal calibration via the goggles a handful of times. Are you talking about something beyond that?
Doing a search for "avata 2" gimbal calibration/calibrate doesn't seem to bring up anything useful
https://www.youtube.com/results?search_query=gimbal+calibration+%22avata+2%22
4-14 08:10
USER001
erutan Posted at 4-14 08:10
Here is an IMU calibration for the Avata. It should be pretty much the same thing for the Avata 2.
4-14 08:11
erutan
The IMU checked out as being fine, and that isn't a step that has been recommended in troubleshooting, but I can give it a try later.
4-14 08:58
erutan
The video basically just mirrors what the on screen process describes.
I got a passing IMU check, still gimble issues.  The errors it gives are intermittent, sometimes stuck, sometimes not, sometimes motor overload, sometimes not. Sometimes it's just a calibration, and once on starting it up the motor moved the camera so it would be centered.
4-15 16:27
USER001
erutan Posted at 4-15 16:27
I found a video on gimbal calibration on DJI Avata. It should be the same for the Avata 2.
https://www.youtube.com/shorts/1KWOXvxu3-o
4-16 01:23
erutan
I've performed the gimbal calibration test many times. It generally fails at 10%, once it got to 60%.
Errors are intermittent as per https://forum.dji.com/forum.php? ... 767&pid=3291784
Unfortunately I'm no longer near a store to do an exchange, but I'll try a more extensive cleaning of the gimbal.  I had assumed "debris" referred to larger objects than dust or sand.
4-16 09:26
USER001
erutan Posted at 4-16 09:26
Errors are intermittent as per https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=310767&pid=3291784
Yes, you should do a good cleaning. Often that helps.
4-17 00:29
erutan
No dice. Used some compressed air and moved parts around. It moves cleanly.  Sometimes the camera will align itself when I turn it on, but I get the same gimbal errors after that.
4-17 12:48
USER001
erutan Posted at 4-17 12:48
You are right. With my Avata 2, I have the same issue. It is stuck at 10%, but I twice managed to get it to 60%, but nothing more. I'll create a thread about it and attract some attention, and hopefully get a helpful answer. Once I get a good answer from somebody, I will tell you.
4-18 07:47
erutan
We ended up heading back to a major city ahead of time due to some bad weather, I was able to exchange it at a Best Buy for a new one, it's been working normally on a few flights now.
5-4 12:39
USER001
erutan Posted at 5-4 12:39
Great! And on my Avata 2, I did not replace it, but the gimbal calibration got to 100% this time.
5-5 01:26
