Deltaxel
Czechia
Hi,
I usually record in 25 fps because of the light flicker in many venues I work with.
And I use tentacle sync to provide timecode to all my devices.
Like most external timecode providers, the max fps is 30 for the tentacle sync.
I was asked to record a video in 50 fps for a customer.
I kept the the timecode to 25 fps. Since 50 is a multiple of 25, I was expecting the camera to be able to correctly extract timecode on the correct frame.
Not only it didn't wotk, but the camera fully brake in this scenario.
There is no error message.
The record button does nothing.
The lidar information disapear and the auto-focus gets manual.
What is execpted:
Camera should work properly (auto-focus, recording).
If timecode is incompatible, a warning should be displayed. Or an error if you're going to block recording.
If possible, support timecode for multiples of the framerate.
I tried re-starting the camera it was still broken. I had to re-installing the firmware.
However, 50 fps with 25fps timecode still doesn't work and might brake the camera again. |
