JJB*
Flight distance : 12401030 ft
Ground_Pilot Posted at 4-27 04:43
I can't seem to copy the .txt file from the folder to this reply, but I opened it in the free flight log viewer and copied the url. You can see that the home point seems to have ultimately wandered off to the north, but it was recorded at the take off point...........and you can see that I paused the auto landing to adjust the descent away from the wrong homepoint to land where the home point was originally supposed to be. I don't know if the wandering homepoint is a bonefide issue or not, but I do find it a bit annoying. Thanks for taking a look.
https://www.phantomhelp.com/logviewer/GKLS6W90BWEI01KKWT2W9FEFIQPBIU89
Hi,
Thanks for sharing your log.
HomePoint was recorded at 3.8s, just after takeoff, drone in the air. This is normal.
At 55.4 sec in flight HP was reset to the drone position, approx 3.1 meter away from the first HomePoint.
First HP was set with 15 satellites and a '5' for signal quality, second HP set with 19 sats and again a '5'.
HP is set if the number and signal quality is oke for an accurate HP position, seen in the app by a white GPS icon (white >= 4)
So in your log with a '5' HP should be accurate enough for the whole flight.
I had once a similar HP reset in flight, this after 8 minutes in flight....
Curious what DJI will say about your 'HP reset in flight' .
cheers
JJB [ Charts by FRAP ; the 'best' software for data and visual flightlog analysis (www.jjbfrap.eu) ]
