Active track problems
694 4 5-14 05:48
YCATTTT
I'm new to drones but the active track on my Mini 4 Pro does not look like the videos.
I have set subject scanning after take off, video sets at normal mode, 4k ,30fps.
I can get the green window at the target.
But when click the active track button, 3 submodes appear, i.e. auto, manual, parallel.
Then press auto followed by GO button.
The trace wheel at right lower corner didn't show up . But just normal navigation circle.
The drone did track the subject automatically.
But NO "DOUBLE CIRCLE TRACE WHEEL".
The Aircraft Firmware is 01.00.500 (I've checked for updates)
The RC Firware is 02.02.0000.       _ I don't have an option to check for updates on the controller - but I believe it is the latest version.
Any help appreciated!
5-14 05:48
The Ollie
Flight distance : 140128 ft
Did you chose the mode "auto" ?
5-14 05:58
YCATTTT
The Ollie Posted at 5-14 05:58
No I chose manual. And also tried parallel.
5-14 06:38
fans179354ab
im having this same problem in manual tracking....when go is pressed, a message says to press icon in lower left of screen. it does nothing  and no circle trace wheel
6-25 12:37
Va1entin2
Flight distance : 639170 ft
Romania
this is because the trace window is minimized in the bottom left. Click on the bottom left icon and the two circles will appear
6-25 12:54
