Go app performance degrades with iOS 9 on iPad Mini 3
1293 4 2015-9-19
sandeep
DJI,
Go app performance degrades with iOS 9 on iPad Mini 3 and 4, with or without H/w decoding .
kindly tweak and test the performance of the app in the new OS.
2015-9-19
mfortunato
Flight distance : 430207 ft
Portugal
The same for me with the iPad mini 3.
The image blocks.
Before the IOS 9 happened when the iPad was very hot, now is almost permanent.
2015-9-19
rhayhurst
Flight distance : 904442 ft
mfortunato Posted at 2015-9-19 12:50
The image blocks.
Before the IOS 9 happened when the iPad was  ...
Same here exactly.  Reducing transmission rate to 4 helps.  I had issues at 6, but when moving down to 4, I was able to fly further.  IOS 9
2015-9-21
rhayhurst
rhayhurst@mac.c Posted at 2015-9-21 08:30
Same here exactly.  Reducing transmission rate to 4 helps.  I had issues at 6, but when moving down ...
Reverted back to previous iOS 8 something, reinstalled the Go App, first flights this morning using an iPad 2 were perfect.  Weather 73 degrees.  Not writing video to iPad, I don't need it and it probably requires CPU or GPU time.
2015-9-24
bahamasboy
Flight distance : 13845 ft
Same think today on Ipad mini 2.   Reduced image transmission rate down to 4, turned on airplane mode after setting home point, HUGE lag up to 20 seconds or so.  Hardware decoding turned on.  The only think I forgot to turn of was the video write to the ipad.   Will try again later and report back.
UGH!!  I have a walk to shoot in two weeks...crossing my fingers I get this worked out before then!
2015-9-26
