dferreira
Flight distance : 979964 ft
Portugal
Hello to everyone!
As an Inspire owner I firstly want to say that my drone has been amazing since February and I' never had any dangerous situation. For me is one of the most reliable drones I've ever seen.
Yesterday I was flying it at a sunset party with no problems at all. One of the batteries had a strange behaviour. From about 30% dropped to 7%...fortunately i was about 50cm of the ground! And landed safely. My concern is that I read a lot of things around this forum and I can't find any clear answer.
I will tell you the conditions of that particular flight to see if you can help me:
- Cold night, about 11 degrees celsius.
- I flew with the battery at 100% charge to about 35% and then landed and shut off the drone (without any problems). I can't be precise but aprox. half an hour later I flew again with the same battery with the rest of the charge remaining (the drone wait outside but I've put later a shirt to cover it from the cold).
- The area I've take off was saying it had interferences and the compass had an error, I've tried several times to calibrate with no success.
- Moments later when I turned on again the drone, the compass had no error but when the drone was ascending only Atti Mode was available.
- I've departed 15 meters away from that area of interferences with other battery and had no problem. Later I have even flew above that area, again with no problems at all (even though the departure are was not the same.
Any clues about what it can be?
I have 4 batteries, all of them have about 15 charges. What do you recommend to preserve them the best way, and how to do it?
Thank you in advance
