RichJ53
Flight distance : 1837356 ft
Hi Houston,
I do not have the problem to the level you are experiencing. The plastic on the holder is the bearing surface and plastic will continue to wear at this point. Once the plastic is worn away there will not be enough material to create the friction needed to hold your iPads weight.
Using the present design, you may add a large nylon flat washer underneath the screw to give you new purchase on the mount to let you get this assembly tight again.
Hope this helps
Rich |
