nick.amtower.gm
Hi,
Bought a phantom 3 pro back in July, I've flown it maybe a couple dozen time since then. Back in september/early october I updated to the new firmware, and two things happened. I was flying it one evening, and then I got this alert on the app. "Danger, Low voltage" or something along those lines and it immediately started coming back to home. I thought maybe it was a problem with the battery so I switched out to the secondary fresh battery. I turned it on and it just started beeping continuously. The app seems to indicate that there might be some issue with the compass. I read in some other threads to open it up and take a look to make sure that all connections are good. Went ahead and did that, and saw nothing loose/broken. I tried putting the firmware on a fesh card, but still no dice. At this point I'm lost and not really sure why my $1300 toy that I've hardly used isn't working.
If yall have any advice, I'd really appreciate it!
Cheers!
