Phantom 3 Pro - Motor Failure
4272 16 2015-11-27
doug.upthink
Flight distance : 861621 ft
While landing my P3Pro on Wednesday evening during a sunset flight, I noticed an unusual sound. Upon closer inspection, I discovered that one of the motors was on the verge of complete failure. It appears that it started to unwind itself. The motor was in normal condition when I performed my preflight inspection. It's slightly alarming to think that I was flirting with disaster while in the air...
Pictures below.
I have 194 safe flights w/ 20 hours and 43 minutes of flight time on this P3Pro since purchasing the quad in late July 2015.
Although this should be a warranty claim w/ DJI, I opted to personally disassemble the entire quad yesterday morning. I removed all 4 motors and will be replacing all of them.
While doing my own repair (so I don't get stuck waiting weeks/months with a DJI claim) I also discovered that 3 out of 4 of my main board mounts had cracked off the battery housing / main board mounting platform somewhere along the way. Luckily, the rest of my P3Pro body didn't have any cracking in the usual places that seem to get most users (i.e. on the motor mounts, etc). The unlucky part is that this is the ONE part DJI doesn't sell. I redesigned the part in Cinema4D and I'm currently in the process of printing it on my Ultimaker 2 today. If anyone from DJI is reading this, please PM me if you have an OEM replacement you could send my way.
Has anyone else had a Phantom 3 motor go out like this? p3_motor2.JPG p3_motor1.JPG
2015-11-27
Mad_Angler1
Flight distance : 2741657 ft
can you post a picture from under the motor,  is the C clip in place ?
has the bearing failed ?
2015-11-27
doug.upthink
Mad_Angler1 Posted at 2015-11-27 14:01
The bearing and C clip are still in place. It appears that the mount was machined deeper than it should have been and the bearing has started to pull out by pushing deeper in somehow. In this image, the damaged motor is on the LEFT. A good motor is on the RIGHT. Both still work, but the bad motor is obviously super wonky due to how it has managed to deform itself. Very strange.
2015-11-27
Mad_Angler1
i guess that hole goes all the way through to the top bearings, so it seems the bearing is pressed in and its not against anything,
2015-11-27
doug.upthink
Mad_Angler1 Posted at 2015-11-27 14:22
i guess that hole goes all the way through to the top bearings, so it seems the bearing is pressed i ...
You're probably right. I would imagine the design would include an inner lip to prevent the bearing from pushing in like that. I wonder if anyone else has experienced this issue? Could it be why DJI has revised their motor mounts in the new 2312A design on all new P3's?
2015-11-27
Mad_Angler1
doug.upthink Posted at 2015-11-27 19:34
You're probably right. I would imagine the design would include an inner lip to prevent the bearin ...
TBH i have not seen it posted across anywhere else so its looks to be a unusual failure,
could be worth stripping the motor to see whats behind that bearing
2015-11-27
gregg1r
I'd try getting some Loctite cylindrical locker and the primer, wet the surface below the bearing and slowly push in the shaft to get back to the correct height.
You'd be looking for Loctite 609. Intended for bearing close fit installations.
2015-11-27
jag01usn
Are you going to disassemble the bad motor? If you do, could you please post pictures of that also. I'm interested because I'm a machinist.
2015-11-27
DJI-Patrick
Hi , Doug
Sorry about that . Please contact American support center for that : http://www.dji.com/support?www=v1 .
2015-11-29
doug.upthink
DJI-Patrick Posted at 2015-11-29 22:29
Hi , Doug
Sorry about that . Please contact American support center for that : http://www.dji.com/su ...
Support request submitted. Thank you.
2015-11-30
DJI-Patrick
doug.upthink Posted at 2015-12-1 01:09
You are welcome !
2015-12-1
artmanmike
Flight distance : 5246 ft
Could you tell me what the outcome from DJI was on this? I had a motor fail causing a crash and they are blaming aftermarket props
2018-5-11
fanscda56185
India
doug.upthink Posted at 2015-11-27 11:12
[view_image]
Will you please help me regarding p3 pro ccw motor ,i need one motor .if you have any spare of 2312 ccw motor please let me know.am using am p3 after 4 years since its crashed .now i need one ccw motor .pls let me know in jkjvisual@gmail.com
2021-12-7
Mark The Droner
Flight distance : 2917 ft
https://www.ebay.com/itm/2543209 ... SwDAddYnvX#shpCntId
2021-12-7
cheddar-man
Flight distance : 44062 ft
Where are you fanscda56185? Plenty of 2312 motors around, especially on Ebay.
2021-12-8
Mark The Droner
cheddar-man Posted at 12-8 00:44
By the way, the motors are all the same. To change the direction of rotation just swap two wires over.
Sorry but that isn't correct due to the prop thread differences.
2021-12-8
cheddar-man
Mark The Droner Posted at 12-8 05:23
Good point - sorry
2021-12-8
