SOLVED "Confuced" P3Advanced acting like Standard
1416 10 2015-12-1
hallfalc
Norway
My Phantom 3 Advanced seems to think it is a Standard(!). At least that's what appears in the DJIgo-app. It allso insists on downloading the latest update for p3Standard, and shows no feed from the camera. When RC is on, the leds light steady red (Critical error). When RC is off it shows fast yellow flashing (RC signal lost).
I have tried running several updates for Advanced (v1.3 - v1.4 - v1.5), but every time it follows this sequence:
Gimble led
- green blinking (warming up?) 1 minute
- green/red alternating (update in progress?) 1 minute
... sequence looping until empty battery.
Has anyone experienced anything similar? Any ideas on how to fix this, or what could cause the aircraft to start acting like "standard"?
Could a service bin file reset the aircraft, and where can I obtain such a file?
Any suggestions are deeply appreciated.
2015-12-1
jasper7821
Flight distance : 1515312 ft
My P3 Pro also would have a popup box saying something about update available for P3 Standard. Dont know why.
If you start the app and on the main page that shows your aircraft are you unable to connect to it? If so, swipe left or right to another aircraft then back to yours and see if the "How To Connect" is gone then you can get into your aircraft. Don't know if you were having that problem or not but just trying to help.
2015-12-1
hallfalc
Norway
jasper7821@yaho Posted at 2015-12-1 20:46
My P3 Pro also would have a popup box saying something about update available for P3 Standard. Dont  ...
Thanks, but the RC connects to the aircraft...only it detects Standard when it should be Advanced. If I only turn on the remote, I can swipe to choose the right aircraft. But when I turn the aircraft on, it will change back to Standard. Once connected I no longer have the option to swipe between aircrafts.
I can allso enter camera-mode, but it says "no signal" and "update required".
2015-12-1
hallfalc
Norway
Sometimes upgrade log (/MISC/LOG/) reads:
[00000857][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00000855][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00000856][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
Upgrade generates no log file in ROOT directory.
2015-12-1
IMI193
This won't help, but apparently the app gets confused, I have a P3S, but the DJO GO app gave me a Adv/Pro version update message, it still appeared to update correctly, of course I have not flown yet.
2015-12-1
jasper7821
hallfalc Posted at 2015-12-1 13:56
Thanks, but the RC connects to the aircraft...only it detects Standard when it should be Advanced. ...
Ahh, I see. Don't know what the issue is then, sorry
2015-12-1
Mad_Angler1
Flight distance : 2741657 ft
can you post the full hidden log file
2015-12-1
DJI-Patrick
Hi ,
This is really weird . Could you please post the update log here ?
2015-12-2
DJI-Patrick
IMI193 Posted at 2015-12-2 05:55
This won't help, but apparently the app gets confused, I have a P3S, but the DJO GO app gave me a Ad ...
Hi,
The announcement appears once you start the DJI Go . Even if you are not connect the device to the drone . Since Phantom 3 pro/adv use the same app with Phantom 3 standard , the announce will come out when new firmware released .
2015-12-2
juanpaulofloren
Malaysia
Had the same exact issue. Though the battery i have came from a P3S (had one before that i sold w/out the extra battery). I noticed everytime i used the battery that came from the P3S package it does pop-up prompting me to update the FW of the P3.
Its actually more of a nuissance really. I usually have to restart everything from the RC to the P3 inorder for it to know its a P3A not a P3S.
2015-12-2
hallfalc
Norway
Thank you all for your engagement. I changed the ribbon cable, and this SOLVED the issue. The RC/DJIgo-app now recognize the aircraft as advanced. After this update was no problem.
2015-12-5
