Flight Logs
1688 8 2015-12-4
marc.aries-serv
Since the last firmware update for our Inspire pro my flights don't appear in my flight logs, has anybody else had this problem ?
I am connecting up using an ipad and the DJI Go app, all up to date.
Thanks
2015-12-4
Alastair
Flight distance : 96631 ft
If you're talking about "flight records" (the little paper airplane in the upper left corner) then you just re- synchronize with the cloud.  If you didn't save in the cloud, then they're probably lost.
2015-12-4
RichJ53
Flight distance : 1837356 ft
The flight records will appear again after you log into your DJI account for each aircraft. I also, save these on the iCloud to keep records.
To paper airplane is where the flight records are viewed on the new App.
Rich
2015-12-4
DJI-Tim
correct the flight records that was synchronized before will be available on the other devices after logging  in to your DJI ID
2015-12-6
marc.aries-serv
Thanks for the replies, just re-read my post and probably should have worded it differently.
My flights prior to upgrade are logged its the flights after the upgrade that I have made that didn't record in the flight logs, all flights prior to upgrade have been synced and still show in the logs when I view them in the DJI app.
2015-12-7
DJI-Ken
Flight distance : 1515312 ft
In your flight record screen is there an arrow to the right of you avatar. If so, maybe another account was created and could be there. The last arrow to the right is recovered Data, could also be in there.
2015-12-7
marc.aries-serv
DJI-Ken Posted at 2015-12-8 00:58
In your flight record screen is there an arrow to the right of you avatar. If so, maybe another acco ...
Ken, I logged out of my account for the App and now cant sign back into it.  Spoke with DJI support on 8.12.15 about this problem and was told its because I have a "hyphen" in my email address but they haven't come back yet with a solution.  However I can sign into my DJI account online no problem, its just the DJI Go app I cant.
Therefore until something is sorted I cant get into DJI Go to look at your suggestion
2015-12-10
DJI-Ken
I'm sorry to hear that, if you create a new account in the app you should be able to get into it.
2015-12-10
marc.aries-serv
DJI-Ken Posted at 2015-12-10 14:42
Have done that Ken, but I have had to use a different email address.
Can I now link that to the email address where my previous flights have been logged, and if so how?
2015-12-10
