Datalink 2.4 Ghz Air end not working and some thoughts
1130 1 2015-12-5
dariodm
Hi all,
after a lot of work with my s900 with a2 and the 2.4 Datalink i'm in trouble with the air end of the datalink set.
After powering on the s900 the air end shows no led. No red, no green, nothing.
Tryed to update it via ground end but it can't recognise the air end.
Any suggestion?
I also want to extend some thought to dji...
the datalink with ground station is now seasoned.
There are better and newer systems. Do you think it's time to build a new sistem to do autonomous flights with our dji copters?
Maybe a solution working with more operative systems and not only with apple products. I think you will sell a lot of them if you renew and build it for android or pc based systems.
Thanks
2015-12-5
DJI-Cathy
If there is no LED on BTU, please plug the BTU and double check whether the PC ground station works or not
Or connect the BTU directly to your A2 to see whether you can access your A2 on DJI assistant APP
If you did all the troubleshooting, pls send your BTU for repair, besides, thanks for your suggestion
2015-12-8
