Steady Red Light and Compass Err Message
2072 6 2014-12-26
martin
Austria
Dear ladies and gentlemen,
i am a complete rookie and hope you can help me!
I had my first flights with my phantom 2 - and it works amazing.
On my last flight i crashed from about 5 feet. No damages from the outside as far as i can see. But now when i turn the phantom 2 on i get a steady read light (after the power on self test). See image attached. I connected to the pc and there i get the compass err message (see screenshot!).
The copte still turns on the usual way - and would lift off but i am too afraid to fly.
Please help me - i would really use my days off now to fly a little - it was so much fun!
I am really counting on your help.
Greets
Martin (from Austria)
2014-12-26
Gerry1124
Connect the Phantom to the computer and do an IMU calibration.  Also check your compass connection on the leg and make sure the wires are intact and plugged in securely.
2014-12-26
martin
Austria
i did both:
the imu calibration was done - no change
i controlled all the cables - nothing seems to be loose - still the same problem
what i realized is that in the imu calibration the gyroscope and acceleration numbers are changing as i move the copter but the compass(raw) data all stays at zero. - see attached image
Hope you guys can help me! I want to fly so badly.
2014-12-27
whyley27
check the connection in the phantom itself bud, might be a loose connection in there
2014-12-27
martin
Austria
whyley: I did that
2014-12-28
Tahoe_Ed
Flight distance : 2605 ft
martin@formafot Posted at 2014-12-28 03:02
i did both:
i controlled all the cables - nothing seems to ...
If all your connections are correct and firm, then you may need to contact your dealer for repair/replacement.  The compass values should be between 1400-1500 in my experience.
2014-12-28
gil
Flight distance : 1379308 ft
Probably the compass is magnetized and you need to degauss it.  Get a small magnet, keep it about 1-2 inch away from the compass and move it both vertically and horizontally around the compass.   Then do the compass calibration again.  Check the compass mod value by connecting to the software. Check the mod figure and see if it gets any better.
2014-12-28
