DJI X5 High ISO NOISE AND FLICKERING
1651 3 2015-12-7
Filmax
Norway
Is there no one here on this forum who have problems with noise when putting higher ISO values. My X5 starts showing noise flickering even at ISO 800. This is a bad product, I deliver this product in before the cancellation period expires???? Or movies you only in daylight ???  X5 camera is worse in the dark than any other Micro Four Thirds camera. This is not innovation.   http://www.rcgroups.com/forums/showthread.php?t=2492900&page=164
2015-12-7
DJI-Amy
In DJI GO, please check whether you are recording in PAL or NTSC format and confirm that it matches the format that is used by your display device. NTSC (60 Hz) is standard in the United States and Japan. PAL (50 Hz) is commonly used in EU countries and in China. Your video may appear blurry if it is not formatted correctly for the display device you are using. About the noise, we will solve the probelm as soon as possible.
2016-1-8
Westwoodfilms.c
weird i did a test yesterday and did boost it to iso1600 and i am impressed with the low noise. Straight out the X5 only did a white balance thats it.
2016-2-11
Westwoodfilms.c
https://youtu.be/Dxwg-a8Hp-s
2016-2-11
