reeltime123
Hi, I just got my Phantom 3 Advanced last week and took it out a few times. when I powered it up it said that I needed to update the firmware, Now i did one when I first got it last week but a new one just came out. When upgrading the firmware it failed a few times before I downloaded a new one from the web site as I figured the one I downloaded 1st may have been corrupt. After I sucessfully installed the new Firmware Version P3S_FW_V01.06.0040. it powered up fine, the camera works like it suppose to but when I go to start it up I get a EMC error. Now I go back to the logs and they look fine, I am thinking something in my EMC has decided to die from the Firmware or its just a fluke that it decided to die. I am going to paste the logs below as someone may be able to help me. Also is there a way to revert back to the old firmware? Maybe this would fix it. Any info would help, thanks...If any tech support guys are reading this please help asap... My wife was already questioning why I needed a 1500 drone and she is riding my tail because I bought a piece of Junk, lets prove her wrong...The attched log file is the root directory and the one in Misc as I did not want to put the other log file on here as it is alot longer....
========== 2015.12.19 16:43:25 =====================
Packet: P3S_FW_V01.05.0030.bin
Upgrading ...
========== 2014.01.01 00:00:12 remo-con disconnect======
Upgrading ...
Result: Success.
Packet: P3S_FW_V01.06.0040.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Failed.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
========== 2015.12.24 13:52:33 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
========== 2015.12.24 13:59:29 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
