Phantom 3 Standard firmware update
1610 11 2015-12-30
vincent.trapena
Hi guys,
so....
i did make a mistake and turned off my P3 while it was updating, now i have this annoying beep.
i think i have read everthing there is to read on how to fix it and cant find a way.
On the professional the firmware is available on the site so it makes things easy (format SD, copy firmware on computer and put it back on P3 and let it update alone
but....
the firmware for the standard is nowhere to be found.
someone said by deleting the app and downloading it again it would ask for the fiurmware update but it doesnt.
Can anybody help? i have lost countless hours on this and i feel i am right where i started.
thanks
VT
2015-12-30
Wholly
Did you ever have any luck?  Or have you contacted support?
I have a different issue entirely and am looking to see if anyone else has the same trouble.  I won't hijack your thread but I can say that it did take about 30 minutes and the app did tell me when I put in the extra battery that it had to be updated.
2016-1-10
ezebunandu.eloc
Having same issue as you, VT.
Please let me know if and when you find a solution.
My bird is grounded for now
2016-1-11
DJI-Patrick
ezebunandu.eloc Posted at 2016-1-11 17:20
Please post your upgrade log file here . Thank you !
2016-1-11
ezebunandu.eloc
Nigeria
Last login: Tue Jan 12 19:04:21 on ttys000
/Volumes/NO\ NAME/MISC/LOG/P3C_CAM_VERSION ; exit;
Samuels-MacBook-Pro:~ Hezeb$ /Volumes/NO\ NAME/MISC/LOG/P3C_CAM_VERSION ; exit;
: command not foundSC/LOG/P3C_CAM_VERSION: line 1: ?
/Volumes/NO NAME/MISC/LOG/P3C_CAM_VERSION: line 2: ?: command not found
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions...none found.
[Process completed]
2016-1-12
ezebunandu.eloc
Nigeria
I am not even sure what to do at this point. Why the heck does DJI not include a link to download the phantom standard update file on it's website. Now I am stuck with a corrupted update, I have formatted my SD card trying to fix same, and I can't find anywhere to download a new firmware...and the customer service is just plain embarrassing....three days and my email hasn't been replied. I am just angry I wasted money buying this stupid drone that DJI seems unwilling to provide tech support once they deceive you into buying.
2016-1-12
DJI-Ken
Flight distance : 1515312 ft
ezebunandu.eloc Posted at 2016-1-13 02:16
I am not even sure what to do at this point. Why the heck does DJI not include a link to download th ...
Here's a suggestion for you. Since you turned off the Phantom 1/2 way through the update and cannot fly now and deleting the reinstalling the app doesn't work.
Try a different device and install the DJI GO app, sign into your account and power up the aircraft and see if it will start the update over again.
2016-1-12
ezebunandu.eloc
Nigeria
Tried that...didn't work. No prompt to install a new firmware.
2016-1-12
ezebunandu.eloc
Nigeria
Hey @VT. Have you had any luck yet getting the Phantom 3 standard firmware update file?
2016-1-13
evermom4aj
What is the latest firmware nimber, please?
2016-1-16
ezebunandu.eloc
Nigeria
DJI-Patrick Posted at 2016-1-11 10:52
This is the upgrade log file:
[00364033]========== remo-con disconnect. boot(15) ============
[00364155]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x297e3c81].
[00364190]Packet upgrade start...
[00364226]Packet checking...
[00364269]Packet vlink 01.03.0050 <-> 01.02.0040.
[00364334]Done.
[00364368]Version checking[1]...
[00364408][01 00][00] v1.10.3548 -> v1.13.4312 need upgrade
[00364443][01 01][00] v1.10.3548 -> v1.13.4312 need upgrade
[00364484][04 00][00] v1.41.0.0 -> v1.41.0.0
[00364561][03 05][00] v34.2.0.9 -> v34.2.0.9
[00364638][03 06][00] v2.3.0.13 -> v2.4.10.7 need upgrade.
[00364705][09 00][00] v0.1.0.8 -> v0.1.1.0 need upgrade.
[00364802][12 00][00] v5.9.0.0 -> v5.9.0.0
[00364886][12 01][00] v5.9.0.0 -> v5.9.0.0
[00364970][12 02][00] v5.9.0.0 -> v5.9.0.0
[00365047][12 03][00] v5.9.0.0 -> v5.9.0.0
[00365156][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00365191]Done.
[00367225]Waiting for user confirm...
[00377269]Timeout, start upgrade automatically.
[00377338]Firmware upgrading[1]...
[00393214][01 00] Firmware upgrade start...
[00013850][01 00] Firmware upgrade finished successfully.
[00013915]Done.
[00013969]Packet [C:\P3C_FW_V99.99.9999.bin] resumed, card sn [0x297e3c81].
[00014047]Packet vlink 01.03.0050 <-> 01.02.0040.
[00014133]Version checking[2]...
[00014193][01 00][05] v1.13.4312 -> v1.13.4312
[00014224][01 01][00] v1.10.3548 -> v1.13.4312 need upgrade
[00014272][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014342][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014419][03 06][00] v2.3.0.13 -> v2.4.10.7 need upgrade.
[00014486][09 00][00] v0.1.0.8 -> v0.1.1.0 need upgrade.
[00014583][12 00][00] v5.9.0.0 -> v5.9.0.0
[00014667][12 01][00] v5.9.0.0 -> v5.9.0.0
[00014751][12 02][00] v5.9.0.0 -> v5.9.0.0
[00014828][12 03][00] v5.9.0.0 -> v5.9.0.0
[00014986][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00015023]Done.
[00015060]Firmware upgrading[2]...
[00015224][01 01] Firmware upgrade start...
[00045527][01 01] Firmware upgrade finished successfully.
[00045665][11 00] Firmware upgrade start...
[00094192][11 00] Firmware upgrade finished successfully.
[00094461][03 06] Firmware upgrade start...
[00486601][03 06] Firmware upgrade finished successfully.
[00486664][09 00] Firmware upgrade start...
[00529637][09 00] Firmware upgrade finish without reboot.
[00559677][09 00] Firmware upgrade finished successfully.
[00559719]Done.
[00559757]Version checking[3]...
[00559793][01 00][05] v1.13.4312 -> v1.13.4312
[00559829][01 01][05] v1.13.4312 -> v1.13.4312
[00559914][04 00][00] v1.41.0.0 -> v1.41.0.0
[00559993][03 05][00] v34.2.0.9 -> v34.2.0.9
[00560112][03 06][05] v2.4.10.7 -> v2.4.10.7
[00560174][09 00][05] v0.1.1.0 -> v0.1.1.0
[00560260][12 00][00] v5.9.0.0 -> v5.9.0.0
[00560346][12 01][00] v5.9.0.0 -> v5.9.0.0
[00560425][12 02][00] v5.9.0.0 -> v5.9.0.0
[00560520][12 03][00] v5.9.0.0 -> v5.9.0.0
[00560651][11 00][05] v1.8.0.0 -> v1.8.0.0
[00560683]Packet upgrade finish successfully.
[00014031]========== remo-con disconnect. boot(15) ============
[00014068]Packet [C:\P3C_FW_V01.02.0040.bin] detected, card sn [0x297e3c81].
[00014105]Packet upgrade start...
[00014149]Packet checking...
[00014200]Packet vlink 01.02.0040 <-> 01.01.0030.
[00014241]Record vlink 01.03.0050 <-> 01.02.0040 (flow = 1).
[00014273]Done.
[00014305]Version checking[1]...
[00014352][04 00][00] v1.41.0.0 -> v1.41.0.0
[00026893][11 00][00] device not detected.
[00026930][01 00][00] v1.13.4312 -> v1.13.4312
[00026968][01 01][00] v1.13.4312 -> v1.13.4312
[00039504][03 05][00] device not detected.
[00052057][03 06][00] device not detected.
[00052127][07 00][00] v1.0.9.14 -> v1.0.9.14
[00052176][09 00][00] v0.1.1.0 -> v0.1.0.9 need upgrade.
[00064710][12 00][00] device not detected.
[00077248][12 01][00] device not detected.
[00089788][12 02][00] device not detected.
[00102334][12 03][00] device not detected.
[00102370]Done.
[00104404]Waiting for user confirm...
[00114451]Timeout, start upgrade automatically.
[00114606]Firmware upgrading[1]...
[00114669][09 00] Firmware upgrade start...
[00138571][09 00] Firmware upgrade finish without reboot.
[00168607][09 00] Firmware upgrade finished successfully.
[00168642]Done.
[00168683]Version checking[2]...
[00168724][04 00][00] v1.41.0.0 -> v1.41.0.0
[00181260][11 00][00] device not detected.
[00181292][01 00][00] v1.13.4312 -> v1.13.4312
[00181324][01 01][00] v1.13.4312 -> v1.13.4312
[00193864][03 05][00] device not detected.
[00206405][03 06][00] device not detected.
[00206495][07 00][00] v1.0.9.14 -> v1.0.9.14
[00206552][09 00][05] v0.1.0.9 -> v0.1.0.9
[00219084][12 00][00] device not detected.
[00231631][12 01][00] device not detected.
[00244176][12 02][00] device not detected.
[00256721][12 03][00] device not detected.
[00256763]Packet upgrade failed at version checking.
2016-2-6
tricks46
Do what I did and go to the original or a firmware the was on the bird.  Clear the sd micro chip clean and load the old firmware on it.  Start the drone with the new firmware plugged in
2016-3-1
