Donnie
Flight distance : 3636782 ft
Wind and temperature also play a huge factor. Temperature because the colder it is the faster those batteries are going to drop voltage. Wind is also a major factor , always do mini test returns to see how that wind is up at altitude. A good indicator is when your phantomis flying away from you going 38mph you know you are going downwind, a short way out I will test that wind, if I can return only go say 8 mph, that is going to limit how far i go out.
Good cycling of batteries and proper discharging will give you long flight times as well. Beau had an excellent suggestion with the back panel C1-2 buttons. Always a good idea to monitor those cells individually.
I take my batteries down to 25 % rather than 30 to increase flight time. I am always monitoring Temp, Wind, Volts and orientation of my bird.
Have fun, this is an awesome hobby and this technology is only something I dreaamed about as a kid.
Cheers Donnie
