DJI-Ken
Flight distance : 1515312 ft
ALWAYS, make sure to download the correct firmware for whichever aircraft you have.
Since you put the Advanced on the SD card now (formatted before) and the camera gimbal light is Red/Green that means it is updating Since you stopped it while updating before it may also be making loud single beeps, but if you put your ear close you should also be able to hear the firmware updating beeps DDDD, DDDD, DDDD and when it's finished (20-30 minutes) the gimbal light will turn solid green and the firmware beeps will be D-DD, D-DD, D-DD and continue to make those beeps. If you get that, then your done and it all worked.
You can verify by putting the SD card in your computed and reading the TXT file, scroll to the end and it should say success.
