Kneepuck
Flight distance : 275105 ft
Since I just crashed my advanced yesterday, I can speak on this with some authority. First, it's not as bad as it seems. In fact, it's not as bad as mine. You can buy a gimbal repair kit that is exactly what you need to fix the gimbal for about 50 dollars. If you are a little handy with tools, it is an easy fix. Those wires with plastic things hanging out are the antenna. Chances are, you can glue them back in place. In my case, the camera broke the entire gimbal assembly off inside the camera body art the swivel. I had to replace the entire camera/gimbal assembly. I found a brand new one on ebay for about 350.00. A set of props can be had for about 20 dollars. And don't forget, you don't need the camera to fly. So, to sum it up, from the appearance in your pictures. it will cost less than 100 dollars in parts. And the labor is pretty simple.
