SVTRay
Generally speaking,
Printing can be a science on its own. Anyhow, it comes down to DPI, dots per inch. The more DPI, The better the resolution. Lets say you start out with 300 DPI which is typical.
12 MP @300dpi can produce a high resolution 15 X10
12 MP @200dpi can produce a good resolution 21 X14
12 MP @150DPI can produce an ok resolution 28 X 18
You can print larger at lower dpi but the resolution starts going down quick. Now with that said, I would think you could print up a 20 X30 and still look good. This is why i use a 36 mp camera...only wished I could afford a drone that could carry it.
Another thing when it comes to printing is how is this picture going to be viewed? 3ft or 4ft away? 3 ft would need 200 PPI (Pixels per in similar to dpi) while 4ft would need 150-175ppi. The closer you get, the higher the resolution needs to be.
