A2 Abnormal Compass Warning WILL NOT CALIBRATE
4391 11 2016-2-6
fromabovetx
I have the A2 of course. I had the GPS Pro. I thought that was  the problem . I overnighted a GPS Pro Plus. with either compass, I get the abnormal compass data. The LED is flashing Green/Yellow. I am running 2.7. Please see picture. I must ship this from texas to Hawaii by Monday. Or I stand to lose Thousands of $$$$!!!!
A2Setup
A2Setup
2016-2-6
fromabovetx
Also, Motors will not spool up in any mode. With or WITHOUT compass attached.
2016-2-6
dennismurry08
Flight distance : 5948264 ft
fromabovetx Posted at 2016-2-6 08:23
Hi, I have a friend over in Bulgaria that has the flashing green/yellow but his copter flies...maybe between both of you, maybe compare notes? Here is his link and video...please keep us advised if you solve it and what it was.
http://forum.dji.com/thread-40933-1-1.html  I've also asked a coulple of friends to see if they could weigh in...hopefully they can get an answer to you before you lose your filming.
2016-2-6
fromabovetx
Thank you. I have found that if I orient the IMU left or right versus straight forward the compass will calibrate. This however makes the motors spin in a very odd manner. Even configured correctly in the assistant software. The motors go crazy. I think it is a bad IMU. I have changed to a wookong that i have but fear I don't have enough channels with it.
2016-2-6
Tahoe_Ed
Flight distance : 2605 ft
Fromabovetx what are your mod values for the IMU?
2016-2-7
fromabovetx
All of the values are set at 0. If that is what you are asking
2016-2-7
fromabovetx
I take that back. We are positive 1cm on the X. That is it. Should that be a negative since the IMU is at the front of the A/C ?
2016-2-7
DJI-Amy
Hi, please try the following method:
1) Connect to assistant software and check whether the control mode reflects correctly or not.
2) Observe the compass value and change another place with fewer interference and try to calibrate again.
3) Switch problem of the remote controller. Please replace the channel and switch.
2016-2-16
aceresco
Flight distance : 409987 ft
Hi if you're the person what haved problem with A2 GPS  green an yellow light  went you takeoff or  you put the ruder left o right an start  green an yellow light , the situation is the battery  make an interference with GPS . I made one base for installation GPS more higher the battery top an I removed GPS base to rear frame, an I putt aluminum films  use in kitchen an put 6 films one over one  then covered al IMU except barometric hol on Side the IMU overall on IMU an F Controllers
2016-4-5
DJI-Adela
aceresco@prw.ne Posted at 2016-4-6 13:28
Hi if you're the person what haved problem with A2 GPS  green an yellow light  went you takeoff or   ...
It could be possible that the battery has an influence on the GPS compass module.
Thanks for your update.
2016-4-6
jlavalle1
Can anyone give an exact fix for this problem? I am a graduate student and I proposed buying a S900 with A2/GPS Pro Plus for environmental/forestland research. My program spent $4,500 on a platform and I have been setting it up for my professor. I am having the exact same problem. Last week after a ton of emails and phone calls to our DJI dealer and DJI Pro Customer Support I was told the problem was a faulty GPS Compass. We spent an extra $89.00 to get a new replacement GPS Compass Pro Plus. I took it out in a field today, installed the new GPS compass and got the exact same Error message again. Again my situation is exactly as what fromabovetx detailed in this thread, Can anyone give a solution?
2016-8-6
jlavalle1
Can you describe this fix a bit better? I'm not sure what you are saying to do.
2016-8-6
