The Low Battery RTH Work - Video Demonstration
zutama
Indonesia
Hello Everyone, good morning from Yogyakarta, Indonesia...
I just want to share a video demonstration showing the function of the low battery Return-to-Home (RTH) from the DJI Phantom 3. I used a Phantom 3 Standard for the video.
In advanced, I apologized if the same thread already discuss before. I hope the video will be useful especially for the new pilots, thank you.
best regards,
Zaki
2016-2-7
j30trouble
Flight distance : 441010 ft
Thank you fir the videi
2016-2-7
Elmer Fudd
Nicely done.Thanks.
2016-2-7
dewayt
Flight distance : 641224 ft
i would be worried about it being critically low and having to ascend so high to come home.. would stink if it used to much power to get to the proper altitude for failsafe.
2016-2-7
zutama
Indonesia
j30trouble Posted at 2016-2-8 09:01
Thank you @j30trouble
2016-2-7
zutama
Indonesia
Thank you @Elmer Fudd
2016-2-7
zutama
Indonesia
dewayt@gmail.co Posted at 2016-2-8 11:56
i would be worried about it being critically low and having to ascend so high to come home.. would s ...
Yes, that is true @Dewayt, sometimes I changed the failsafe altitude depend on the surrounding conditions, but mostly higher than 80 m, thanks...
2016-2-7
mrolrac
Cyprus
zutama Posted at 2016-2-8 09:22
Yes, that is true @Dewayt, sometimes I changed the failsafe altitude depend on the surrounding con ...
Thank you, very helpful indeed.
2016-3-28
zutama
Indonesia
mrolrac Posted at 2016-3-28 15:00
Thank you @mrolrac, great if it can help.
2016-3-30
GM01
Belgium
Thanks for taking the time to put the video on the forum - good to see this feature in action  !
2016-3-31
zutama
Indonesia
GM01 Posted at 2016-4-1 01:09
Thank you @GM01
2016-3-31
DJI-Ken
Flight distance : 1515312 ft
Great video.
I set my RTH altitude anytime I fly in a different area. That way if flying in an open field there's no reason to expend battery juice by ascending too high.
BUT, if you set a low RTH when in an open field, you cannot forget when flying with tall objects around.
2016-3-31
rreindl
Flight distance : 6491926 ft
Thanks for sharing.
2016-3-31
zutama
Indonesia
DJI-Ken Posted at 2016-4-1 09:21
Great video.
I set my RTH altitude anytime I fly in a different area. That way if flying in an open  ...
Thank you @DJI-Ken, setting RTH altitude become one of my mandatory checks before fly.
2016-3-31
zutama
Indonesia
Thank you @rreindl
2016-3-31
DJI-Ken
zutama Posted at 2016-4-1 12:32
Yes, make that part of your preflight checklist.
You would not believe how many crashed have happened when someone flew behind a skyscraper and lost signal and RTH is started and the aircraft crashes into the side of the building.
Always remember know where you are going to fly and set the RTH altitude higher than the tallest structure in your flight path.
2016-3-31
thumb
I think if I had to set my altitude for a higher setting that it might be a good idea to set your low voltage to maybe 35% just for a little more time to get home.
2016-3-31
gmezg
I hadn't that about that. I've had mine for about 3 days now and yesterday I changed my RTH Alt. to 360 Ft. it's not crazy high but I would hate myself if it did waste battery climbing too high if not required. Thnaks
2016-4-5
